never satisfied, looking for deeper 12s
#61
as you can tell they dont use the same transmission cooler lines like the 60/65/75/80e
im going to try and find a stock cooler line set up and go from there.
http://bowlertransmissions.com/item-details/?iid=687
i can buy this block with -6AN fittings and run my own lines, but then id have to figure out what size fittings id need at the radiator.
the 6L80e's are 3/8" whats the 60e size? 5/16"?
#62
#63
Guessing it would be comparable to somehwere between 4.56 and 4.88s but look at skeets times and 60ft (I know your trucks a lot heavier and won't launch like a 4linked 3500lb truck) but I was just wondering about 4thgear compared to the 6th gear of the two trans
#67
Nope. The BW transfer case in our trucks is actually an open center differential, so the truck won't move if you disconnect the front driveshaft.
#68
Gear ratios on the 6L80E:
1st- 4.027:1
2nd- 2.364:1
3rd- 1.532:1
4th- 1.152:1
5th- 0.852:1
6th- 0.667:1
Reverse -3.064:1
Note that, unlike any other transmission GM has produced, there is no 1:1 gear ratio :-
4th is an underdrive and 5th is an overdrive ratio.
1st- 4.027:1
2nd- 2.364:1
3rd- 1.532:1
4th- 1.152:1
5th- 0.852:1
6th- 0.667:1
Reverse -3.064:1
i cant wait!
