my rebuild
Old Sep 2, 2013 | 05:59 PM
  #31
TIM Z's Avatar
11 sec. Truck Mod
What gears you running ?
I like the sound of what you may be doing interior wise , I'm not feeling the wood pieces I have either .
Old Sep 2, 2013 | 07:06 PM
  #32
iamkeniff's Avatar
I have 4:11s and a tru-trac. When this rear end gives me issues ill be swapping to a 14 bolt and maybe a 4 link idk.
Old Sep 14, 2013 | 08:52 AM
  #33
iamkeniff's Avatar
Well i cut the egr port off and welded the hole up. Pure stupid idea on their part but its not a bad job to weld the hole up.
I need to get my flanges expanded to slide over the header then ill weld it up.
The motor needed to have the crank polished so we just swapped in a brand new crank. The cam and crank were installed when i dropped off my oil pump monday. They plugged the dod bosses too, cut the block for a 4" crank if i ever go bigger. They worked their a$$ off to get my block damn near perfect.
I should be getting the motor back this weekend but we'll see.
Old Sep 14, 2013 | 09:04 AM
  #34
iamkeniff's Avatar
The PCV tube was cut off and drilled out for a -6an setup to go to the intake tube.
The factory coil harness is extremely crappy once you break it open to work on it.
Got it straightened out and shrink wrapped waiting to solder in the extensions vs chopping up my engine harness
Old Sep 15, 2013 | 09:37 PM
  #35
AUTOT3K's Avatar
They plugged the dod bosses too.
did the 6.2's have EGR at some point?
whats the benefit to plugging the DoD bosses? just cover yourself in case one of the o rings on the valley cover fail?
Old Sep 15, 2013 | 09:51 PM
  #36
iamkeniff's Avatar
No i bought 99-06 headers, they use to have the egr which was pointless.
As for the plugs its no point in having them when you dont have dod/afm. So why keep them open?
Old Sep 15, 2013 | 10:09 PM
  #37
GMCSIERRA5.3's Avatar
Maybe i missed it but what converter are u going with?
Old Sep 15, 2013 | 10:18 PM
  #38
AUTOT3K's Avatar
ohhhh ok cause I was trying to think...didnt the gen 3's have egr, but the headers thing makes sense
good call on blocking them off, I could see an issue if one of those o rings on the valley cover wore out
are you gonna leave the valve covers bare or any thoughts on powder coating?
Old Sep 15, 2013 | 10:20 PM
  #39
iamkeniff's Avatar
Im going to clean them up and paint them with VHT then do the CAI tube.
Yabk Pro Truck 3600 triple disc
Old Sep 17, 2013 | 07:58 PM
  #40
iamkeniff's Avatar
Pacesetter 1 7/8s fit the 07-08 frames just fine
Moved the main harness to the back of the intake. Seriously 6 or 8 wires need to be extended and thats it!
Added a new style steam vent system.
