My cheap lowering "kit"
Old Dec 19, 2017 | 07:46 PM
cadmaro's Avatar
Default My cheap lowering "kit"
Couldn't bring myself to pay a ton if money for how little I wanted to lower my truck. I decided to cine up with a way to do it cheaply. Front struts flipped to under the a-arms and 2" shack with removed blocks in the rear. Spent $14 on grade 8 bolts, nuts and washers for the front and about $60 for the shackles and spacers for the u bolts.
Old Dec 19, 2017 | 10:08 PM
silver-mod-o's Avatar
Hunt&Fisherator
Post some pics of that front end setup. I'd be interested to see it!
Old Dec 20, 2017 | 08:25 AM
mcfarlnd's Avatar
Un-Registered User
I did did the same thing. First pic is before second is after.
Old Dec 20, 2017 | 08:32 AM
mcfarlnd's Avatar
Un-Registered User
I also had to get a camber kit from rough country to get the alignment correct. I didn’t have enough adjustment left. That was probably the most difficult part due to grinding the upper control arm holes.
Old Dec 20, 2017 | 11:06 AM
BudRacing's Avatar
How much did this method drop the truck?
Old Dec 20, 2017 | 11:37 AM
dsmmace's Avatar
I'm not sure I'd be comfortable with those bolts not breaking off with downward force from a pothole. I bought the Belltech 2/3 drop kit myself.
Old Dec 20, 2017 | 12:37 PM
terravast4's Avatar
i agree
Old Dec 20, 2017 | 02:07 PM
mcfarlnd's Avatar
Un-Registered User
I live in a pothole.... New Orleans. The roads are awful here. I understand the concern though. The kit from rough country does the exact same thing and figured why not. Driving on it for about 6 mos. now without problem. I consistently check the bolts and haven’t had an issue with stretch but, usually a grade 8 will just snap before stretching.
Old Dec 20, 2017 | 02:08 PM
mcfarlnd's Avatar
Un-Registered User
2” in the front and the rear was about 3”
Old Dec 20, 2017 | 03:36 PM
Hunt&Fisherator
I considered doing this on my 07 CC truck but didn't feel comfortable with the whole front end of the truck relying on those 4 bolts to keep it from catastrophe lol. I opted for the bell tech struts. They worked out great.
If you drive one like this around Louisiana, you have bigger ***** than I
