LS3 timing chain faliure
Old Jul 14, 2010 | 02:35 PM
supercharged680's Avatar
Exclamation LS3 timing chain faliure
has anyone heard about these timing chains failing or sumthing does it happen too often or not i found this..
https://ls1tech.com/forums/generatio...failure-4.html
since ill be changing the oil pump soon i might as well change the timing chain to cloyes.. to be on the safe side
Old Jul 14, 2010 | 04:38 PM
09sierra6.2's Avatar
seems like underdrive pulleys have some issue causing them to do that from what some say.. personally never heard of anything like that happing around where i am to anyone but doesnt mean it cant...
Old Jul 14, 2010 | 04:55 PM
Robert91RS's Avatar
I have not seen any failures in my service dept thus far. I can also tell you that the part number for an LS2 and LS3 chain are the same in my catalog and many of the LS1 guys use them as an upgrade on mild builds. After reading the thread you linked I got the impression there was more to it than just a timing chain. Most of those guys were running road races and a underdrive balancer. I'm new to this forum so I don't know how much of this info you're already aware of, but I haven't heard of any issues here.
Old Jul 14, 2010 | 06:53 PM
i talked to a few guys.. some had built motors and believe it or not a few where BONE stock... im guessing its a matter of luck...
Old Jul 15, 2010 | 09:43 AM
that rights pure luck!!! i race dirt late models and modifieds, we prolly spent around 20,000 on an all aluminum 358 motor, well ran fine for bout 3 races then boom, everything new no used parts and put together buy the same person the same way he did the 370 motor thats a season old and still kickn.. no explaination for it just luck like you said! now it wasnt a timing chain that broke but same idea, eventually everything will break just depends on how long before it does!! he** idk how but my uncle has a 377 motor with a 80's model sbc that has been running and not refreshed ever and it was built in 2001 and we still give that motor all its got, were trying to get it to blow up!!
off the side note there if your worried bout it i would upgrade anyway if you have the money to! couldnt hurt but then again there not 100% bullet proof either.. good luck man!
Old Jul 15, 2010 | 11:01 AM
Preston129's Avatar
I would blame the underdrive pulley and its influence on the harmonics of the chain, rather than the chain being inherently weak.
Old Jul 15, 2010 | 03:26 PM
cam's Avatar
cam
Upgrade to the IWIS German made single chain and NEVER look back. To my knowledge no one has ever broken one. They run these in the C5R for 24hrs at LeMans and Katech sells them. Im running the model down IWIS which is still a VERY sweet chain but you can get the one Im running at SDPC for $45.00
You can actually see the quality if you see one in person and how amazingly smooth and precise it is. Its like butterrrrrrrrrr LOL
Old Jul 15, 2010 | 03:45 PM
Preston129's Avatar
^Are you running the chain on the stock sprockets?
Old Jul 15, 2010 | 03:50 PM
Quik's Avatar
5 year bitches!
The problem lies with the harmonics at lower rpms as it puts more strain on the links. That's why you see the geniv motors with chain dampers in them. The asp pulley yhose motors using are known to cause issues
Old Jul 15, 2010 | 03:51 PM
cam's Avatar
cam
Yes stock sprockets. Its a direct replacement
Im about to put a powerbond UD pulley on though. I havent seen any issues with them only the ASP
Any experience here?
