L92 VVT Cam
Old Sep 19, 2015 | 07:12 PM
Aaron Arceneaux's Avatar
Default L92 VVT Cam
My 09 Escalade, recently spun bearing due to oil pump failure. I've been talking to a few companies about a vvt cam for it while I have the engine disassembled. It's 1 7/8 headers, 4in exhaust, cai, ported ls3 tb, and circle d 2800 converter. I've been looking for something to make decent power, sound near stock(stealth), and still have ***** to pull my car hauler.
TSP recommended either vvt1 or 2
Comp has recommended their 401 cam, but don't have phaser tables.
Mast told me their L92 ho cam, but I've been reading that their customer service isn't up to par and hard to get assistance when needed.
Many others have told me do away with vvt all together.
It's currently street tuned, but will be brought to patg for dyno tune once put back together.
Old Sep 19, 2015 | 08:00 PM
smokeshow's Avatar
Mod with training wheels
Whatever you do, don't use another GM high volume (VVT) pump unless you deburr the relief valve bore. That's the most common reason why they fail. Relief valve hangs and you lose all oil pressure.
Old Sep 19, 2015 | 09:47 PM
I'm running a melling 10355 high volume
Old Sep 19, 2015 | 09:49 PM
That's exactly what happened and thrashed the thrust bearing beyond saving. New crank going in as well.
Old Sep 22, 2015 | 05:22 PM
Chavette's Avatar
Why not get Pat to spec you a VVT cam for a custom grind?
Old Oct 1, 2015 | 02:35 PM
He's actually the one tuning it, but i was pressed on time and couldn't wait that long for one to be grind, I ended up getting comp 401, that was closest to what he spec'd for my needs. I'm thinking about bumping compression up with thinner head gaskets while im in here
Old Nov 15, 2015 | 08:11 PM
Medic/Z28's Avatar
Anybody hear of Brian Tooley racing cams? That's my other option.
Old Nov 29, 2015 | 12:33 PM
I went with a btr stage 3 truck cam for my vortecMAX truck since several other friends used him and had good luck
Old Dec 21, 2015 | 02:54 PM
Medic/Z28's Avatar
I had called Comp Cam, Brian Tooley, MAST, Lunatii and TSP and they all either had recommended to keep it or delete it. So, I went with 3-bolt cam, deleted the VVT and pulled the trigger on a Circle D too. Couldn't be happier. Gas mileage... well we don't buy 6.2s for their economical and environmental contributions so it sucks. I can always drive the vette if I want to be cheap.
OHsixLS3
Dec 27, 2016 09:30 AM
rednekferlife101
32
Jan 8, 2016 10:42 PM
USMCvet0311
Sep 30, 2015 10:34 AM
USMCvet0311
Jul 29, 2015 01:28 PM
Matt331
Jul 26, 2015 09:40 PM
