Flip Kit + Drop Shackle = Lower or Higher???
Old May 24, 2010 | 04:38 PM
FrankyRST's Avatar
Default Flip Kit + Drop Shackle = Lower or Higher???
I was emailing back and forth with stylin trucks and they totally confused me.
They first told me that if I got a 7" flip kit with a 1" drop shackle that would raise me up to a 6" drop. Then they said the opposite and told me that a 7" flip kit with a 1" drop shackle would lower me down to a 8" drop. huh?
So does a drop shackle on a flip kit raise or lower the drop?
Old May 24, 2010 | 04:54 PM
Dezert1500's Avatar
On the GMT900 a flipkit is a 7" drop.
A shackle with the 7" flip kit will raise the back to 6" drop.
Old May 24, 2010 | 04:59 PM
DV2000NJ's Avatar
13 Second Truck Club
A 1" lift shackle will, but a drop shackle will still be a drop shackle.
Old May 24, 2010 | 05:02 PM
RandomHero's Avatar
No he was right the first time. The 07-Up trucks have a flipped shackle setup so a longer shackle will raise the rear of the truck and a shorter shackle will lower it.
Old May 24, 2010 | 05:05 PM
DV2000NJ's Avatar
So the flip kit includes a shackle flip too...?
Old May 24, 2010 | 05:10 PM
RandomHero's Avatar
No one ever said that.
He's asking about the new style trucks(07-10). They are totally different than the 99-06 I'm assuming you're referring to. The shackle mount is flipped when compared to a 99-06.
Believe me man, between the two of us(Dezert1500 and me) we have done a few static drops in our time.
Old May 24, 2010 | 05:17 PM
DV2000NJ's Avatar
That's news to me, every GMT900 I've seen has had the same shackle setup as the GMT800s.
Is it a 2wd/4wd difference? I'm not sure I've been under a 2wd, but I'm just about positive all the 4wd GMT900s I've seen have had the same style shackle as my truck.
Old May 24, 2010 | 05:22 PM
FrankyRST's Avatar
Lol, its confusing right.
So If I want a 6" drop, I could go with the Belltech 7" flip kit with a McG 1" drop shackle?
Old May 24, 2010 | 05:39 PM
Three6GMC's Avatar
ummm im lost too I just put a flip kit on my buddys 09 and the way its setup if you put a drop shackle its gunna drop it nothing changed with the suspension besides instead of the axle sitting under the leaf spring it now sits on top but that has nothing to do with how a lowering shackle works on this specific kit..... i think the kits you guys are talking about are the ones were it flips the rear shackle over with a new hanger then in that case yes a lowering shackle will actually lift it but those kits are not 7 inch drop kits only the ones were the axle is phisicly moved from under to over the leaf springs like in my case
Old May 24, 2010 | 05:41 PM
Three6GMC's Avatar
I have a 09 crew cab 2wd and my dad has a 09 crew cab 4x4 no dif what so ever in the suspension
