Drivetrain issues help!!!
Old Nov 1, 2011 | 02:18 PM
6.slow432's Avatar
Default Drivetrain issues help!!!
Can someone help me figure out the problem
I put it in drive an it dont go its like if its in neutral i have a 3200 circle d torque converter i dnt think its tranny but idk could be wrong it dont seem like its transfering the power to tranny i really think its the torque converter that is jacked up i need some advice!!!
Thank yall!!!
Old Nov 1, 2011 | 02:33 PM
skeet's Avatar
this a new install of the torque converter? if so did you seat the torque converter all the way in the transmission? does it go into any other gear and the truck moves? if its a new install you may have busted the pump by not seating the torque converter properly. or you could have to much clearance between the torque converter mounting feet and flexplate which will pull the hub out the pump!
pull a line off the tranny, put it in gear and see if the pump is pumping, if theres no fluid you have damaged the pump when installing the torque converter
Old Nov 1, 2011 | 08:14 PM
You crushed the oil pump/// pull a oil cooler line off the radiator and see if there is any fluid flow. If none drop tranny get another oil pump or parts to repair yours and start at step 1 again.
Old Nov 2, 2011 | 08:51 AM
6.slow432's Avatar
I wasnt the one that installed the torque converter
So i really dnt know if it was installed wrong but it does sound like if its something to do with the torque converter idk im going to change out the torque converter to the stock one see wat happens!!!
Old Nov 3, 2011 | 11:23 PM
If you don't take the oil pump apart you are probably wasting your time dont chance it take it apart and verify that it is ok and not squashed.
Old Nov 21, 2011 | 08:37 PM
6.slow432's Avatar
Sorry guys ive been busy these past weeks so i pulled the oil cooler line off the radiator an theres no flow through it so i guess its the tranny oil pump then how much does that cost!!!?
Thanks guys
Old Nov 22, 2011 | 08:59 AM
6.slow432's Avatar
Bump ttt
Old Nov 22, 2011 | 10:14 AM
this truck was running for about 2 months after converter install
Idryfly5
Sep 2, 2022 08:55 PM
murderedSS
27
Oct 12, 2015 11:13 AM
TAPyvehc93
Sep 14, 2015 01:22 PM
dselby25
Sep 11, 2015 05:03 AM
Boyes50
Sep 8, 2015 12:06 PM
