anyone ever tried to sump a stock tank? would this work?
so I was talking to a buddy who was big in to diesels a while back and we were talking about plans for my truck and I mentioned that I wish someone made an aluminum sumped tank like we use to have for the f-bodies back in the day and he mentioned alligator performance's no drop tank sumps. I will post the link below, but do you guys think this thing would work for an efi setup? I know for a diesel and gravity feed it would suffice, but for our high pressure systems would this be a safe option? what do you guys think?
ADP Diesel Fuel Sump NO TANK DROP REQUIRED!
I sump'd my Escalade with a Hellmann sump feeding an external A1000. Waste of time and money.
First issue was if I ran the tank below 1/4 and came to a fast stop or moderate acceleration off the line the pump would cavitate.
Second issue and the one the really ticked me off was I couldn't drive the vehicle for more than an hour at a half of tank of fuel without vapor locking. That was even with using the voltage controller.
After sitting on the side of the road a couple of times waiting for the fuel to cool back down I yanked everything out and went with a dual in tank setup. No vapor lock issues but it will still lose pressure launching off the line with less than 1/4 tank.
With that said maybe a different pump that wasn't rated at 600 lb's/hr you could have better results with the vapor locking but with no baffling in the tank the potential for cavitation will always be there.
It's fine to sump it it will work but I would run the factory pump in the bucket for normal driving around and just kick on the external pump with a Hobbs switch at wot only. Have seen that done on a couple daily driven setups with no issues at all. Mine is actually gonna be ran like this.
Why not use the Aeromotive Stealth? Ive already installed one in a 502 Camaro with no cavitation issues. Used the stock tank but did install foam in the tank to slow down the fuel slosh. Just did not want a sump showing in the rear.
ARC
57
Feb 21, 2022 10:54 AM
GMCtrk
Jul 17, 2015 06:39 PM
