6.2 Stroker
Old Jun 17, 2013 | 01:42 PM
slow2008's Avatar
formerly slow03 (11-04-2011)
Default 6.2 Stroker
So I found a stroker kit using standard bore for our 6.2's to make it a 416 with scat forged crank and rods and probe forged pistons. Is it possible to replace the rotating assembly without removing the block? Thanks guys.
Old Jun 17, 2013 | 04:53 PM
02 BLK WS6's Avatar
10 Second Club
It could be done but there's no way in hell I'd waste my money on good parts and half *** a build. It's nearly impossible to check all of the tolerances with the block still in the truck and it will take longer too. Cylinders will need a good hone. Rings file fitted. Rotating assembly balanced.
Old Jun 17, 2013 | 05:10 PM
silverado6.2's Avatar
As mentioned above, Don't bother. The only thing left in the truck would be the block.
Old Jun 17, 2013 | 09:20 PM
slow2008's Avatar
Yeah, good point. Some days I just want to be lazy. Lol.
Old Jun 17, 2013 | 10:55 PM
AUTOT3K's Avatar
I see a crank disaster coming from that haha
its stressful enough dropping the crank in let alone trying to hold it up and put the main bearing caps on!
do it right or don't at all cause whatd end up happening is it'll fail and then you'd need all the parts again PLUS a block!
Old Jun 18, 2013 | 06:46 AM
slow2008's Avatar
Yeah, This thread gets the dumbest question of the week award. Was day dreaming in the middle of a 13 hour shift at work.
Old Jun 18, 2013 | 07:34 AM
pewterliftedz's Avatar
I'd vote for you. hahah
Old Jun 18, 2013 | 08:48 AM
TIM Z's Avatar
11 sec. Truck Mod
Don't use a cheap Chinese crank .
Old Jun 18, 2013 | 09:45 AM
slow2008's Avatar
Is scat chinese crap now? Damn...
Old Jun 18, 2013 | 11:33 AM
AUTOT3K's Avatar
That's sad to hear cause like 6 years ago I did a sbc 383 and the scat crank was good quality back then
