4" or more drop questions
Alright guys, I've got Belltech drop struts and about to add spindles to have 4" drop up front on my '07 Tahoe. What is everyone doing to align there trucks? What can I expect before I go in blindly buying crap that I don't need. I'll be running 22's TBSS replicas and haven't decided on a tire size yet either. So some suggestions on tires wouldn't hurt. Thanks in advance.
did you use the 2* bushings when you did the drop struts?
basically adding spindles really wont affect the alignment much other then maybe a minor toe tweak or if they're poorly made caster/camber.
so if your current alignment is good, go ahead and add the spindles
I haven't added anything to correct it yet, I was waiting to do spindles. Im using Belltech spindles. Hope I don't run into any weird crap
If you go with the 22's 305/40/22 work well. They're big and meaty and outer edge of the tire BARELY rubs the rear of the fender liner when the steering is at full lock. -That's with a 2" drop. I went with those tires, because they're considerably cheaper than other tires in that diameter for some reason.
If you are out still an additional 1* you can use these cam plates
99-13 Chevrolet Silverado/Sierra C 1500 2wd/4wd (Fornt end alignment cam lock plate kit 1 degree)
Lamartian92
09-10-2015 09:27 PM
Lamartian92
08-21-2015 01:43 PM
