2007 suburban dod/oil pressure light issue
Old Feb 6, 2017 | 09:33 PM
  #31
About20ninj45's Avatar
Damn that sucks
Old Feb 6, 2017 | 11:13 PM
  #32
Wolftrk99's Avatar
Im getting paid for it.. really depends how you look at it i guess!!
Old Feb 7, 2017 | 08:18 AM
  #33
No. I understand, I'm just saying that's alot of damn workand it sucks That it has to be done what year Yukon?
Old Feb 7, 2017 | 09:40 AM
  #34
Turbo09's Avatar
I have a stock 4.8 cam if you want it 150,000KM on it. This is getting painful lol
Old Feb 7, 2017 | 02:51 PM
  #35
Wolftrk99's Avatar
Its an 07 suburban, she just doesnt take care of it, cant remember the last time she had an oil change done on it...
Old Feb 7, 2017 | 02:54 PM
  #36
Wolftrk99's Avatar
If i end up having to rebuild the engine i may be in touch, if i go that far, i will take the lmg that came out of my yukon and put that in it, with a dod delete, a lq9 or other stock cam, and a set of decent used lifters and rebuild the lc9 for a rainy day and another project!!!
Old Feb 8, 2017 | 01:23 PM
  #37
Wolftrk99's Avatar
Some pics of the carnage
Master cylinder piston seal has been leaking for a while obviously...
Thsi was after i drained about 3qts of brake fluid out of the booster
Oill filler tube seal on her old valve civers wasnt seated properly...
This is what the inside of a valve cover is NOT supposed to look like
Left valve cover is the same way
Oil came out of the pcv line going to the intake, and i dumped a goid biyt of oil out of tge vakve cover
The plugs were fouled but no caked oil, which usually intakes a ring issue .. the plugs are sitting about the way they came out of the engine, 4 on the left in the pic are the 4 from the passenger side , the other 4 are as one would expect are out of if the driver side
Right bank plug wires, saturated with oil!!
Left engine mount
Old Feb 18, 2017 | 03:31 PM
  #38
Wolftrk99's Avatar
And now her oil pan is leaking....again!!! Put dye in it and told her to bring it back up last week and sure enough the pan is leaking, by the starter and below the knock sensor on the passenger side and at the oil cooler block off and a small spot, iirc, close to the front on the left side... although she isnt complaining about it anymore everytime i talk to her!!
Y2KLimited
Dec 5, 2015 09:57 AM
truefire04
Sep 11, 2015 10:51 AM
colekill
Sep 3, 2015 03:19 PM
LQ9Chevy1500
Aug 27, 2015 09:05 PM
ntxf
Aug 10, 2015 10:12 PM
