07-13 Silverado/Sierra Transmission Spacer
Old Jun 17, 2014 | 05:25 PM
TheSuspensionSource's Avatar
FormerVendor
Default 07-13 Silverado/Sierra Transmission Spacer
We finally added the Belltech Transmission Spacer to our site.
This spacer is good for the 2WD models of the 07-13 Silverado/Sierra.
Belltech Transmission Spacer for 07-13 Silverado/Sierra
Old Jun 17, 2014 | 07:41 PM
Jason Z69's Avatar
What is this spacer for?im new to the lowering stuff. I have a2010 silvarado 2x4 im wantin to lower 2inches also. Whats a good kit? Im wanting 2 front and back. Im wanting a better ride quality
Old Jun 18, 2014 | 12:06 AM
FormerVendor
This would be for trucks with flip kits, mainly crew cab & extended. There are certain flip kits that do not come with this piece.
If you want a simple 2" front drop and 2" rear drop, I would suggest using Belltech's Lowering Struts for 2" and 2" rear shackles. Here are some links.
Struts on SALE $75 each
Belltech Lowering Strut 07-13 Silverado/Yukon/Sierra/Tahoe B25003
Shackles
The Suspension Source 88-13 Chevrolet Silverado/Sierra 1/2 Ton (All), 88-10 Silverado/Sierra 2500/3500 (All), 92-99 Tahoe, Yukon & Suburban (4dr. Only) 94-01 Dodge Ram 1500 (All) 97-03 Ford F150 (All) 2" Rear Drop Lowering Kit
Old Jun 18, 2014 | 02:45 AM
silverado1ss89's Avatar
That thing would come in handy on my 5/9 drop
Old Jun 18, 2014 | 09:15 AM
FormerVendor
2WD Regular cabs should not require the transmission spacer, at least not on mine.
Old Jun 18, 2014 | 12:11 PM
Jason Z69's Avatar
Im about to start doing som performance mods. What would be better goin 2 lower front and back or a 2-4 for better traction?
Thanks in advance
Old Jun 18, 2014 | 12:59 PM
FormerVendor
Thanks in advance
You can go as low as 5/7 if you have some horsepower behind the truck. 2/4 is more of a level appearance than the 2/2. Personally I like the 3/5 drops on these trucks. Allows for a bigger tire to be used.
Old Jun 18, 2014 | 07:08 PM
Jason Z69's Avatar
Really? A bigger tire with a 3/5 drop??
Old Jun 18, 2014 | 11:35 PM
FormerVendor
Yea, the Magnuson truck is running 20s by Budnik, 3/5 drop with a larger I believe Nitto tire. Works perfect.
Old Jun 20, 2014 | 03:50 PM
mattdavis12340's Avatar
I have 3/5 kit on my crew cab w/ flip of course and I'm getting quite a bit of bounce. Would this spacer help me out any
