whats that sound?
Old Dec 2, 2006 | 01:45 PM
chevz7102's Avatar
Smile whats that sound?
I have a 2005 gmc truck 1/2ton and was woundering what the sound comeing from the dash is when I turn off the engine it sounds like marbles bouncing around or shomething I think all the 2003 and up g.m trucks do it my moms 2004 silverado 3/4ton HD Duramax diesel also makes the sound when turning off the engine I can here the marble bouncing sound from the dash a little also when the engine is idleing or when I rev it up in nutral. hope to here back from someone about this question thanks.
Old Dec 2, 2006 | 02:34 PM
xchevyx24's Avatar
are you sure its not bubbling or boiling rad fluid?
Old Dec 2, 2006 | 02:40 PM
nicks05z71's Avatar
Iv herd it in my chevy too, i think it has somthing to do with your gauges moving back to they're limit.
BlackLM7's Avatar
My truck makes the same sound from the dash. I sometimes hear it when I shut the engine off but it's really noticeable on cold mornings after I start the engine. I think the noise is coming from the gauge needle servos inside the gauge cluster. I'm not 100% sure though.
Old Dec 2, 2006 | 09:14 PM
budhayes3's Avatar
PT's Slowest Truck
A couple different noises that I think it may be:
1) AC servo motors/blend doors moving to a certain position after the vehicle is shut off
2) the guage needles that were mentioned sounds legit
3) maybe some relays/capacitors powering down?
4) Coolant moving through a rubber orifice in the heater core, but this seems to happen more while the truck is warming up.
Old Dec 2, 2006 | 10:40 PM
TURBHOE's Avatar
i say its the cluster. mine has this sound everytime i load a new tune with hpt. the gauge cluster is testing itself and powering up. or down i guess.
Old Dec 2, 2006 | 10:47 PM
Yes, it's the cluster. My aftermarket unit began doing it, so I sent it off to get the guage motors/ servos replaced.
Its a common problem on the 03' & up GM truck & suv clusters.
There should be a TSB bulliten on this at GM dealerships.
If your truck is still under warranty, take it back to the dealership to be fixed. If no warranty, it's really up to you on what or how you want to handle it.
You would need to either replace the cluster with a new one and have it reprogrammed to your mileage & engine hours that are on the original cluster or just deal with the noise.
Good luck!
Jim
Old Dec 3, 2006 | 03:00 PM
chevz7102's Avatar
thanks for the tip guys I think your right
Old Dec 3, 2006 | 04:14 PM
Forgot to mention that when I placed my factory gauge cluster back in, all the marble/ chattering noises went away.
Jim
lukn4trbl355
Oct 21, 2015 11:19 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
Infernohoe
48
Oct 2, 2015 10:25 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Rockrz
Sep 29, 2015 09:07 AM
