What is required to swap Gen IV engine into Gen III truck?
Old Jun 9, 2016 | 08:42 PM
Lane_Hesser's Avatar
Default What is required to swap Gen IV engine into Gen III truck?
Just wondering what all is required to put a gen IV motor into a gen III truck. Any advice would be helpful. Thanks!
Old Jun 9, 2016 | 08:52 PM
FFDP's Avatar
I won't have all the answers but a few.
To stick a 07+ gen 4 motor in your need to use a 24x to 58x converter box or swap the reluctor wheel on the crank. Something to make the knock sensors work because they are on the side of the block. AFM/DOD delete kit, new cam, timnig chain, cam gear, valley cover, front cover if removing VVT. A custom tune for sure.
Old Jun 9, 2016 | 09:26 PM
I was thinking a 2004.5-early 2007 because I don't want an afm motor.
Old Jun 9, 2016 | 09:32 PM
Jake75's Avatar
Convertor box, cam sensor extension, knock sensor extension, tap side of block for knock sensors I think that's it. Not hard at all I'm swapping a gen 3 v6 to a gen 4 v8.
Old Jun 9, 2016 | 09:38 PM
Wolftrk99's Avatar
that early of a gen iv engine could have the knock sensor provisions in both the valley and the side of the block... Some sort of transition thing.... That being said you may want to check the block and the crank to see if it is a 58x or a 24x, some of the transition engines had the older style 24x reluctor in them, iirc!!
Old Jun 9, 2016 | 09:44 PM
FFDP's Avatar
If you are looking for those year motors, then nothing special is needed at all.
The motors are all basically the same for 99-07(classic), none of them will have AFM/DoD or VVT. Truck motors that is, some SUV's got AFM/DoD but they are considered gen 4 motors in those years.
Old Jun 9, 2016 | 09:46 PM
Wolftrk99's Avatar
Those years were tb, rainier, envoy werent they...for gen iv!
Old Jun 9, 2016 | 09:55 PM
FFDP's Avatar
Yeah and the SAAB's got those early GEN 4 motors too.
Old Jun 26, 2016 | 12:37 AM
Thoagland's Avatar
Just got through putting an ly6 into an 05 silervado. Pm me if you have any questions
Old Jul 14, 2018 | 12:05 PM
Jeremiah Raver's Avatar
Registered User
Default LY6 question
Ive been searching for ways to do this and came across this post and looking for help I have an 02 Silverado with the 4.8 and I also have a LY6 from an 09 Sierra. I have everything for the LY6 from my donor truck including full harnesses, pedal, and even to the cluster. What can I do to pull this swap off? Thanks in advance
Chevy6.Zero
Sep 23, 2016 11:33 AM
Haulinbass02
Jun 6, 2016 10:53 AM
Phantomx55
May 31, 2016 03:58 PM
RoadKill03
May 29, 2016 09:06 PM
rocknZ71
May 18, 2016 08:29 PM
