What oil? Tired of searching.......
#21
Originally Posted by Wheatley
amsoil 10w-30 here
#22
Its really a preference thing. I used to put standard mineral oil and it ran fine, changed every 3-3.5K. I just put in amsoil 10w 30, and Im gonna use the oil life moniter, and see what it looks like when it says to change it.
#23
I am not interested in drain intervals like that either.LOL Crazy if you ask me
I chose them because of several oil analysis tests I sent to a lab using amsoil and Mobil 1.I chose the amsoil after the results came back.
#24
What about royal purple though? Did you match amsoil against it?
#25
Originally Posted by 03GMC
Yeah I think its a little long to go on an oil change too. I might go 10k but that would be changing the filter like 3 times.
I use penzoil or valvoline full synthetic 5w30. Whenever the Change Oil light comes on the first time I just press the gas three times and wait another 7 or so thousand miles. So I go usually 15k between oil changes. The truck has 265k on it and still runs as good as ever. This whole change the oil every 3k miles is a scam that Jiffy Lube and the like do so they can change women's oil more often. Synthetic is synthetic its all good.
#27
Originally Posted by maximumrebel1
Can't really do that without changing the oil.
#29
Why cant you just put on a new filter? I did it a month ago after switching to synthetic oil just to make sure that the filter wasn't clogged with junk from starting to use synthetic. Heard once you switch to a synthetic to change the oil filter about a 1000 miles after because synthetic cleans the motor out. Anyhow I put on the new filter and the oil level went down 2 circles on the stick, not much. Oh and by the way I work at an oil change shop, Penzoil is our sponsor and I would never put it in my vehicle. Quaker is also Penzoil, same company.
#30
Yogi
