Two electric cutouts down in two days!!!
Old 03-17-2005, 11:15 PM
slowprocess's Avatar
Unhappy Two electric cutouts down in two days!!!
Yep, I've had some bad *** luck with my cutouts in two days. First one was the vibration dropping the two screws that hold the motor in the unit. Upon investigation of the other cutout, I noticed that the bar the butterfly sits on is broke at where the screw that holds it to the bar is located. In other words, it will not open and close properly anymore. I am now running open cutouts until I can make some temporary plates for it tomorrow. My neighbors love hearing the truck roll in at midnight with the cutouts open.
Looks like I'll be sending in both units for repair, and I got them in November. I hope they can work with me alittle there.
Old 03-18-2005, 07:52 AM
SimpleManLance's Avatar
ouch! that is shitty. what brand are they. im in the market for some and i dont want mine faling apart.
Old 03-18-2005, 08:14 AM
Truck addict
goshawk23's Avatar
there QTP's. sorry to hear that. maybe you should just go with the poor mans after all. lol. you can always get out at a redlight and jack the truck up then uncap them. kinda like some nascar stufff.
hopefully they'll work with you on this.
Old 03-18-2005, 09:20 AM
GREGGO's Avatar
Tha's just sad. After your other post, I decided to go check mine. I did find a small problem. One of them was not opening. The butterfly was just loose. Now I still have no complaints due to the use that mine get. This is the first problem in over two years. I've definantly gotten my moneys worth out of them. Anyway, my problem was the coupling with the set screws that hold the butterfly shaft to the actuator shaft. The set scre for the butterfly side needed to be tightened. Well of course since I stripped it. So I pulled it off and took it apart. I just retapped a larger set srew in and done. BTW, I went ahead and took the motor off just for grins. Man that sucker was on there. NO WAY it would have EVER vibrated those screw out. They had enough lock tight to hold down a set of heads.
On another note, the heatsheild between the passenger cat and tranny was about to fall off. Both bolts were still in, but just finger tight. I just took it on off. You know to save weight. Must be worth....5oz.
Old 03-18-2005, 10:03 AM
TigerFan187's Avatar
CRAZYCUTER4.8s dad has a 03' SS Procharged,cammed,etc.. and he has the same cutouts you do(elec) and I cant remember exactly what problem he was having and Ill get CRAZY to chime in but he has so much TQ that it was damaging the cutouts-like bending them and stuff.
Old 03-19-2005, 12:36 PM
FormerVendor
Matt@adams's Avatar
I've been shopping for e-cutouts and this is the second time I've heard of QTP's falling apart. Another guy from ss.com (adams2003) just put on a set of butterfly style DHM cutouts...IMO they look much more high quality than the QTP's and they back 'em up w/ a 3 year warranty. Personally I'm looking at a set of guillitein (sp?) style ones... just need to find somwhere to fit them.
Old 03-19-2005, 03:20 PM
vortec327's Avatar
I used the QTP on my 99. NEVER sealed all the way when closed. Always sounded like i had an exhaust leak. What a piece of junk. Had it rebuilt multiple times. Last time it fell apart, it went into the garbage.
This looks like a stout unit, way out of my price range at $500 . Seems to me that a "gate" valve would seal better than a "butterfly valve" http://www.dougsheaders.com/online_s...ail.cfm?id=217
Old 03-19-2005, 03:29 PM
Truck addict
goshawk23's Avatar
maybe it's me, but these electric cutouts are just too damn expensive. i bet i could make one that worked damn well for way less money than they are asking.
Old 03-19-2005, 09:11 PM
02sierraz71_5.3's Avatar
What brand of cutouts would you guys recommend I was looking at the qtp but Ive heard of alot of people having problems. Anyone know of a GP on them?
Vortec350ss
01-12-2016 10:36 PM
bearden86
26
11-15-2015 03:58 PM
turbo6c3
10-05-2015 06:11 PM
SSpeeDEMONSS
10-03-2015 08:21 PM
trxmxzx
09-29-2015 07:42 AM
Quick Reply: Two electric cutouts down in two days!!!
