Transmission drain bolt?
Old Feb 13, 2003 | 11:10 PM
CashDudeHomie's Avatar
Default Transmission drain bolt?
Hey guys I have rounded the bolt off bad and it is stuck as hell and isn't coming out. I picked up a replacement #24213991 for $5. A couple weeks ago on FSC there were 3 other people who had the same problem, but they had to buy the whole pan, so I guess I got lucky. Has anyone here had trouble getting the bolt out? How should I remove it? I have a dremel and a drill, but I am not sure how to approach this without risking damage to the pan. Thanks for the advise. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Old Feb 13, 2003 | 11:20 PM
pony killer's Avatar
Default Re: Transmission drain bolt?
be carefull but try using a little heat should back out. But don't go crazy with the heat. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Banned
go to home depot or any other hardware store and get an easy out, then drill in the middle of the screw and tighten the easyout into the bolt and back it right out.
Matt
Old Feb 13, 2003 | 11:48 PM
Hey thanks for the posts. I don't have a torch but that's a good idea. I will look for some easy out tomorrow.
Old Feb 14, 2003 | 12:20 AM
JSmith's Avatar
My uncle is the tranny guy at my dealership and he said that it's a pretty common problem. He was surprised to see that mine actually came out without damaging the bolt.
Old Feb 14, 2003 | 01:05 AM
I figured it was common. I asked the guy at the dealer if they ever had trouble getting them out for the first time and he said no. <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" /> They must install these with a damn impact wrench. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Feb 14, 2003 | 10:06 PM
parish8's Avatar
single digit dreamer
i think that is an aluminum bolt or something, it is really soft, i messed mineup prety good and ended up useing the next size smaller socket(6sided) and beat it on there and it finialy came out, i would try and get something like that beat on there and use some heat, a little burnsomatic would probably get it done.
Old Feb 14, 2003 | 10:27 PM
really slow truck's Avatar
yep i rounded mine off too, i said screw it and dropped the pan. had to change the filter anyways
zblee
63
Jun 10, 2023 01:25 PM
chopperloco
Jul 10, 2016 10:45 PM
ss454327
Oct 17, 2015 03:43 PM
Mzay
Jul 6, 2015 11:03 PM
