Trans temp guage
I'm wanting to put a trans temp gauge in my truck, was wondering if anyone has done, or knows a way to put a Autometer or similar trans guage in a factory 2000 gauge cluster, in the same place as the Escalade gauge, or if I need to just get Escalade gauges, or a gauge pod?
Here you go should be the same for a tranny temp gauge.
http://www.picturetrail.com/gallery/...551&uid=552911
No the black piece(the bezel) already has a hole in it where the tranny temp gauge would go. You just have to modify the internals of the cluster a bit nothin big just take the bezel off the gauge that you are puttin gin thereand it will look factory. White1 what do you mean overlay lights you mean the cluster lights that light the whole thing up?
While you are at it you might as well do this
https://www.performancetrucks.net/fo...d.php?t=345678
I did it to my escalade cluster and it looks bada$$.
2 1/16" you need a gauge that is going to show from about 140 to 240
somethin like this has the right range on it
http://cgi.ebay.com/ebaymotors/AUTOM...QQcmdZViewItem
1slow, I got a cheep white gauge face, that is back lit, but the ring where this guage will go is lit also, I'll have to see if the lights will still work if I cut this part out, cause its too dark for the factory lights to show thru good.
