99-02 Gauge Cluster Upgrade
Old Jul 31, 2005 | 11:38 AM
Dub Silverado's Avatar
Default 99-02 Gauge Cluster Upgrade
If you want to change the color of the backlight on your gauges, but dont know what all is involved here are the simplest instructions you can find.
Tools:
Small Flat Screw Driver
7mm Socket or Nut Driver
Time: About 20 minutes.
Results: Priceless
Step 1: Order 6 LED bulbs. You will need the 4 bulb 194s. WLED-B4
LED Ordering Page
Step 2: Order 6 Twist Lock Connectors
Twist Locks
Step 3: Take Dash Bezel Off
Step 4: Unscrew 4 7mm bolts holding cluster in the dash.
Step 5: Remove Gauges and unplug Harness.
Step 6: Use a small Flat Screw Driver to pop the clips off the gauge backing.
Step 7: Locate 6 bulb plugs, and Remove
Step 8: Plug new LEDS and new Twist locks
Before reassembling, make sure you plug the harness back into the cluster to make sure all lights are functional. Some LEDs have to plugged into the socket one way only or they will not work. If you have any that are not functional, just turn the bulb 180 degrees in the twist lock and it should work.
Its easiest to do this right before sunset, or else you will have a hard time seeing the lights during the day.
Old Jul 31, 2005 | 01:31 PM
Thats cool man, looks nice and you provided really good info. Thanx. I will be doing this before too long.
Old Jul 31, 2005 | 01:45 PM
OUT2WIN's Avatar
I always wanted to do that with my 99. I love the looks of just one color at night. Anything out for the 03+ clusters?
Old Jul 31, 2005 | 01:46 PM
There is no way to do it with the 03+
Old Jul 31, 2005 | 01:52 PM
white1's Avatar
Makes me want a new set of factory gauges insteas ot the white ones I have.
Old Jul 31, 2005 | 03:38 PM
BlownChevy's Avatar
blownerator
25 Year Member
Outstanding work! I love the results!
Old Jul 31, 2005 | 04:09 PM
ap2002's Avatar
good write up and pics... very helpful information
thanks..
Old Jul 31, 2005 | 04:47 PM
budhayes3's Avatar
PT's Slowest Truck
That looks really good, nice write up too!
Old Jul 31, 2005 | 06:15 PM
RedChevy4x4's Avatar
Will swapping to the Escalade gauges in a truck with a 5-speed trans. work?
Old Aug 1, 2005 | 12:01 AM
TXsilverado's Avatar
i would be all over this if it was easier to change the bulbs in the OEM radio and A/C controls.
also, everyone should know that the dimmer switch will not work after this mod(will still work for radio and A/C). no biggy to me but just so it dosent suprise anyone planing this mod
