Tranny trys to lockup on accell
Old Mar 20, 2009 | 05:28 PM
area1509's Avatar
Default Tranny trys to lockup on accell
Forgive me if this is here some where, but my searches have been fruitless.
What I Did:
1998 GMC 1500 I removed a 305 / 4L60E and installed a 350 / 4L80E the 350 and 80 came together with the wiring harness and computer everything went ok until I tried to start it with the 350 computer it would start and run for about 20 RPM's then **** down so I put the 305 computer in and it runs ok.
Question 1: will the computer make a difference, is there a trick to getting the 350 computer to work?
When I take off from a stop it feels like the lockup converter is truing to lockup right away, this has killed the engine a few times.
it does not feel like the tranny is shifting rite ( rpm goes high i shift it to drive or second to get it to shift )
I am lost at this point.
AJ
Old Mar 20, 2009 | 05:45 PM
Wheatley's Avatar
Truck Sponsor
First,the PCM with the 305 and 4L60E programming is not gonna run the 350 and 80E tranny.It has to be flashed with a 350/80E file.
Now you said the PCM that came with the 350/80E would start and die correct?
If so do the security relearn.98+ has VATS,when you swap a PCM from another truck in your truck,the VATS have to be relinked.
I will pm you the security relearn steps.
So take the PCM that came with the 350 and 80E tranny and do the steps I am about to pm you.
Old Mar 20, 2009 | 05:51 PM
Wheatley's Avatar
Truck Sponsor
PM sent.Do those steps EXACT.If they are not done correctly you will have to start over to step 1
Old Mar 20, 2009 | 06:13 PM
dlt76028's Avatar
^^^^^good advice
Old Mar 20, 2009 | 06:14 PM
area1509's Avatar
Thank you I will give it a try.
Old Mar 20, 2009 | 09:38 PM
area1509's Avatar
Thank you so much! I was starting to think the tranny was junk but it shifts like a dream now.
Now to work out the slight miss it has and it should be good for another quarter million miles.
again Thank You
AJ
Old Mar 21, 2009 | 09:52 PM
area1509's Avatar
Can anyone tell me what this means?
output from scan tool
DTC_CNT 0
FUELSYS1 CL_Fault
FUELSYS2 CL_Fault
LOAD_PCT(%) 13.7
ETC(°F) 198
SHRTFT1(%) -7.0
LONGFT1(%) 6.3
SHRTFT2(%) -6.3
LONGFT2(%) 5.5
MAP(inHg) 16.2
RPM(/min) 1628
VSS(mph) 12
SPARKADV(°) 35
IAT(°F) 102
MAF(lb/min) 5.089
TP(%) 16.9
O2S B1S12--B2S12--
O2B1S1(V) 0.165
SHRTFTB1S1(%) -0.8
O2B1S2(V) 0.445
O2B2S1(V) 0.780
SHRTFTB2S1(%) -1.6
O2B2S2(V) 0.090
OBD Not OBD
Old Mar 21, 2009 | 10:36 PM
area1509's Avatar
DTC_CNT 0----------------DTC Stored Number
FUELSYS1 CL_Fault---------Fuel System 1 Status
FUELSYS2 CL_Fault---------Fuel System 2 Status
LOAD_PCT(%) 13.7---------Calculated Load Value
ETC(°F) 198----------------Engine Coolant Temperature
SHRTFT1(%) -7.0-----------Short Term Fuel Trim Bank 1
LONGFT1(%) 6.3------------Long Term Fuel Trim Bank 1
SHRTFT2(%) -6.3-----------Short Term Fuel Trim Bank 2
LONGFT2(%) 5.5------------Long Term Fuel Trim Bank 2
MAP(inHg) 16.2-------------Intake Manifold absolute Pressure
RPM(/min) 1628-------------Engine RPM
VSS(mph) 12---------------Vehicle Speed Sensor
SPARKADV(°) 35------------Ignition Timing Advance
IAT(°F) 102----------------Intake Air Temperature
MAF(lb/min) 5.089----------Mass Air Flow Sensor
TP(%) 16.9-----------------Absolute Throttle Position
O2S B1S12--B2S12--
O2B1S1(V) 0.165-----------O2 Sensor Output Voltage (B1S1)
SHRTFTB1S1(%) -0.8-------Short Term Fuel Trim (B1S1)
O2B1S2(V) 0.445-----------O2 Sensor Output Voltage (B1S2)
O2B2S1(V) 0.780-----------O2 Sensor Output Voltage (B2S1)
SHRTFTB2S1(%) -1.6-------Short Term Fuel Trim (B2S1)
O2B2S2(V) 0.090-----------O2 Sensor Output Voltage (B2S2)
OBD Not OBD
I guess what I am asking is are these values normal?
thunder550
Oct 8, 2015 04:53 PM
maxspeed05V
Aug 26, 2015 04:21 AM
vipergtrdj
Aug 6, 2015 10:19 PM
ZONES89RS
Jul 22, 2015 12:35 PM
Atomic
Jul 11, 2015 03:51 PM
