Topped my tank off too much.... help
Originally Posted by TurboGibbs
Dropping the tank is 2 bolts. just make sure you run it empty. My 05 has a check valve in the filler neck which keeps you from siphoing it but unhooking the feed line and jumpering the fuel pump relay and you can empty it quick. Pulling the bed takes 2-4 people and dropping and empty tank takes 1.
I'm leaning on it being the gauge as well. The sending unit sends out a max and min which equals E and F. If it is something different then the gauge is most likely bad. Get a new gauge cluster. It will zero out your mileage as well.
Yeah if it's an 03+ the gauge is a good bet. The little motors that spin the needles were poorly designed. 99-02 it would be sending unit for sure.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
someotherguy
Oct 5, 2015 12:49 PM
