Tire rub!!!
Old Apr 6, 2004 | 12:22 PM
Silvette_02's Avatar
Default Tire rub!!!
I've got a 02 Silvy dropped 4/6 (DJM). Just got some 20x8.5 American Racing Torq-Thrust ST's (grey center) mounted day 'fore yesterday. I'm running a 275/45-20 Goodyear GTII.
My rear tires are catching the lip on the inside of the fender a little. Is there anyway I can roll the lip or something? My fronts rub at full lock, but I can deal with that. Part of my problem is the damn thing bounces soooo much with that DJM drop, almost like the springs are too soft.
Also, how do I post pictures? I'd love for you guys to tell me what you think.
Thanks!
Old Apr 6, 2004 | 12:29 PM
LOW2000's Avatar
I had the same issue with my bagged truck when I put on my B. Coddington 20's with the same tire you have. What I did was use an air cutoff wheel to trim that lip back that the tires hit, then just used an air grinder to smooth it out a bit and hit it with a little paint to keep it from rusting. If you are completely lost, I can take a pic of it so you can see where i cut.
Old Apr 6, 2004 | 01:18 PM
you need smaller tires for a 4 6 drop. you need like 255 35 20s . whats yor backspacing to. im ruinning 20x8.5 and i didnt have to roll anything. my backspacing is 4 3/4
Old Apr 6, 2004 | 05:31 PM
LOW2000's Avatar
I'm dropped 7/9, he can run those tires if he trims. The 275/45/20 is same O.D. as the stock wheels which is why he is trying to use them, also, they are about the cheapest 20" tires on the market.
Old Apr 6, 2004 | 05:51 PM
Yeah cheap is good! That is one reason I'm using them, plus I had a set of 285/60-16 Goodyear GTII's and I liked them, so I'm trying their 20 in. tire.
Thanks Low, I understand where your saying to cut, I'll try that ASAP. Was kinda hoping I didn't need to cut, maybe just roll, the lip but I'll do it!
Thanks. Oh, BTW badass truck, low.
Old Apr 6, 2004 | 05:54 PM
My back spacing is 5 3/4 not 4. You can run275 45 20 ive seen it done but all the trucks that have run have eventually rubbed through there inner fender wells.
Old Apr 7, 2004 | 02:33 PM
Dude, the front isn't bad. I was just concerned about the rear. That lip on the inside of the fender on the bed was cutting the **** outta my sidewalls. Its taken care of now, thanks Low.
Old Apr 7, 2004 | 02:45 PM
Really? huh im surprised truck looks good though
Old Apr 7, 2004 | 02:46 PM
LOW2000's Avatar
No prob, its a cheap easy solution and you dont have to worry about your paint cracking by trying to roll the fender lip.
gaps
Oct 15, 2015 02:53 PM
bisqikss
Sep 8, 2015 03:35 AM
screaminian47
Sep 7, 2015 08:20 PM
the owl
Sep 4, 2015 04:09 PM
hackrst
Sep 2, 2015 05:27 PM
