it sounds like my bed is loose
Wearin' da big hat
when i drive and hit pot holes, and it sounds like my tailgate is loose and is banging back and forth, but i have check and it is not loose. Then I had someone ride in the back and they said it sounds like its coming from the front passenger side of the bed. I have look underneath and do not see anything loose, and when i lift up on that side of the bed, it feels tight.
Any ideas?
Any ideas?
Check your muffler.
My mid pipe got bent when I jacked up the exhaust to change a header gasket and the muffler ended up sliding inward a little. It would vibrate up and down, hitting the Heat guard on the bottom of the bed. Which is exactly where you mentioned and makes the same sound you mentioned.
Bent to heat guard up a bit and forced the muffler back into proper position and it was fine.
Hopefully thats all it is in your case.
the only thing I can remember that is on the Front Passenger side is your exhaust and obviously suspension. So check the shox too. I've seen people drive around with a shock just hanging.
Might as well check your u-joints too i guess.
I remember an old TSB about early NBS's having problems with the beds cracking in the upper corners...I would think that would be highly visible if that was the case though...
