Slotted rotors ?s.
Old Jul 26, 2007 | 11:10 AM
Stampede4ever's Avatar
Default Slotted rotors ?s.
Can any damage occure by having this done?
Thanks.
Old Jul 26, 2007 | 12:57 PM
truckmann's Avatar
I can't see why any damage would be done by installing slotted rotors. I wouldn't send stock rotors to be slotted though. From all I have seen most believe the slots to be worth very little. If anything maybe even loosing a little stopping power due to less surface area for the pads to use.
What kind of damage are you talking about?
Old Jul 26, 2007 | 01:46 PM
I'm not really for sure what your question is my freind...
Upgrading to a slotted rotor won't hinder you but it won't help...it just de-crystalizes the pad....you need slotted and cross drilled rotors.
Old Jul 26, 2007 | 02:42 PM
Moddoo's Avatar
Mine seem to to keep the face of the pads glaze free, which = better/consistant braking.
Also run cooler to reduce fade.
Definately feel better than the stockers did.
Old Jul 26, 2007 | 06:00 PM
circusboy's Avatar
the slots let the gases escape. gives a better pad to rotter contact. the holes are for cooling the rotters. at least thats the way I understand it. They look cool, but unless you do a lot heavy breaking there will not be much benefit to having them.
Old Jul 27, 2007 | 04:58 AM
I was thinking of milling a 0.06" deep or so radius groove(s) in the stock rotors.
Thanks.
Old Jul 27, 2007 | 07:08 AM
Boyz, the slotted cross drilled rotors are a definate upgrade from the stock GM rotors because they do alot more than look cool. The resist warping, and that's the major problem with the GM and aftermarket replacement rotors. Here at my new shop....we got a bin with about 200 defective rotors in it! That's GM's most major problem other than the Steering Shafts.
Old Jul 27, 2007 | 07:51 AM
truckmann's Avatar
Just curious, but I've heard people suggest that drilled rottors are prone to cracking. Does anyone know of any evidence to support if this is true or not???
Old Jul 27, 2007 | 09:22 AM
If you get the cheaper ones, yes they do crack. Go with a quality set. SSBC or Powerslot.....ya know.
FlyingLow
Nov 24, 2015 10:05 AM
cousblake11
Sep 9, 2015 06:52 PM
Alco
Sep 4, 2015 04:08 PM
