Oil recommendations.
Old Jul 25, 2007 | 08:11 PM
Red 07 LS's Avatar
Default Oil recommendations.
Well since the truck is still sitting at home with no progress thanks to my lagging insurance, I may as well do an oil change as it just hit the 3k mark.
My question is what do you guys suggest? Synthetic or regular? I always used Mobil 1 synth in the SS, just not sure if it's worth it on the truck or not. Also should I just use the factory recommended weight still?
How about oil filter?
Thanks.
Old Jul 25, 2007 | 10:08 PM
truckmann's Avatar
Try the search button, this has been gone over and over a few times within the past 30 days.
For the cliff notes version, mostly it comes down to personal preference. People are not happy that Mobile has changed their formula. A lot of people like Royal Purple and Amsoil, but they are both expensive. Their is no real downside I have heard to using conventional oil as long as you make regular oil changes as one should. Synthetic oil should allow for a longer change interval over conventional. Of the regular off the wal-mart shelf name brand synthetic oils I have seen no reasoning or evidence that one is better than the other.
5w-30 is fine for most engines and climates however some feel they are adding a level of safety by using 10w-30 on high mileage engines.
For oil filters a Wix 51522 is popular, along with an equivalent Napa gold filter (made by Wix). The K&N filter and Amsoil filters are also good choices for a higher cost. Fram filter are generally considered to be crap.
Old Jul 25, 2007 | 11:16 PM
Red 07 LS's Avatar
D'oh, after browsing forums for six years and on such a tech forum I totally spaced out on searching first. My bad. Thanks for the info tho!
Old Jul 27, 2007 | 08:45 AM
Wilde Racing's Avatar
How do I change this text
I like K & N oil filters, no real tech data. but they look cool, with there nut on the bottom and the hole through the nut so you can safety wire it. lol I also use Royal Purple oil, but it does cost a lot of money....
Old Jul 27, 2007 | 12:21 PM
NegraRCSB2X4auto's Avatar
if you change your oil on time everytime don't worry about it.
Old Jul 27, 2007 | 01:26 PM
ZZebes's Avatar
I like Penzoil Platnium Full Synthetic and the Big Delco Filter. Good analysis so far
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
69z-28
Sep 21, 2015 07:31 AM
Velocity1
Sep 15, 2015 11:29 PM
