Service Brake System
Me & my buddy been fighting with this for a month now.
It's throwing two codes right front wheel sensor & rear axle sensor.
We have replaced both sensors..
SBS light will come on/off during a trip. We thought the drive shaft was bent. So we borrowed a friends, and it does the same thing. The speedo needle jumps a little, and we tried another cluster & it still jumps.
More then likely the problem is coming from what is causing the speedo to jumping, but we can't figure out why it's jumping. We have removed the tail housing & everything looks fine.
Gears match the glove box. We pulled the cover and made sure.
Anybody got any ideas on this matter.
06 gmc cc, stock from what we can tell.
if you searched Service Brake System you should have ran across several threads with suggestions.
Since you've done all of those things the thing I would suggest what fixed mine, replacing the VSS on the tail shaft. (vehicle speed sensor).
hmm.... the only other one that i can remember was a connection problem at the fuse box under the hood. Likely something new that I haven't seen in a thread yet. I've read pretty much all threads with this issue for the past year or 2.
We've tried that too. But what's funny it comes on around 20mph & goes off/on the whole time you driving and the speedo is jumping the whole time. He bought it to the dealer & they can't find whats wrong.
