question on an intake
Old Aug 12, 2008 | 11:49 AM
SSlammed03's Avatar
Default question on an intake
i got a volant and i got a custom made 4 inch tube instead of the regular one so i can get more air... however i dont want it to get too warm cuz i want the coolest air inside how can i keep this from heatin up since its close to the motor.... header wrap??
Old Aug 12, 2008 | 11:52 AM
BlackGMC's Avatar
Resident Retard
I tried the header wrap thing on a metal intake that I had previously and it seem to actually hold in the heat, basically heatsoaking the pipe... It took it longer to cool down.... ABS plastic pipes seem to cool down much faster... Just my .02
Old Aug 12, 2008 | 12:33 PM
SSlammed03's Avatar
so should i get some ABS pipe instead?
Old Aug 12, 2008 | 03:23 PM
nemmarick's Avatar
just using the intake tube volant supplies is fine IMO
Old Aug 12, 2008 | 03:26 PM
BlackGMC's Avatar
Resident Retard
that or use aluminum... I went to a plastic style intake, with a fast reacting IAT sensor...
Old Aug 12, 2008 | 03:52 PM
closet red neck's Avatar
I used aluminum tubing and then wrapped everything from the box to the TB. I remember someone on here giving me **** over it(cough, cough, Cody, cough, cough) saying that it was somewhat a watse but after reading my IAT's, the temp was like 17+ degrees cooler than the outside temp @ that time.
Does it help..........maybe, does it hurt.........no.
Just some food for thought........
James
Old Aug 12, 2008 | 04:00 PM
SSlammed03's Avatar
thanks... what did u wrap it wit
Old Aug 12, 2008 | 04:03 PM
BlackGMC's Avatar
Resident Retard
So your saying that your IATs were colder than the outside temperature?
Old Aug 12, 2008 | 04:21 PM
I'm looking in jegs now........hang on.......need to get another smoke........HAHAHAHEHEHEHE!!!!J/K.......
James
Old Aug 12, 2008 | 04:29 PM
Yes. Well let me clarify this........(unwrapped)if it was 60 degrees out and the IAT temp was 90 degrees(at the maf),(wrapped) if it was 60 degrees out and the new IAT temp is now 73 degrees. What I did was look @ my IAT's with HPT before wrapping the intake system then wrapped it and looked @ my IAT's after its was wrapped and the conclusion was it was at least 17degrees cooler than before @ that givin temperature...........
I'm trying.......
James
