Put in a 5.3 and now towing is horrible
Old May 2, 2012 | 01:12 PM
azchevydude's Avatar
Default Put in a 5.3 and now towing is horrible
I just installed a rebuilt 5.3 into my 01 ECSB. Flat top pistons, 243 heads and a z06 cam. Now that i have 2k miles i took the boat out (3000 lbs) and going up some steep hills could only do 50-55mph in third at 4500rpm's. Truck went up that hill much better when i had the 4.8 in there. Is the cam the problem or something else? Installed 4.10 gears also.
Old May 2, 2012 | 01:15 PM
nonnieselman's Avatar
The cam isnt the perfect pick, but still it should have quite a bit more power/tq than the stock 4.8.
Who tuned it?
ive pulled 8-10k # trailers with my 5.3 back when it was stock and it didnt have any problems like that, something is up..
Whats your transmisison temps?
Old May 2, 2012 | 01:16 PM
BOSS302's Avatar
4500rpm in 3rd only going 50-55? That does not sound right at all. Did you retune? Aftermarket converter? The LS6 cam will move the powerband up a little bit, but not that dramatically.
Old May 2, 2012 | 01:19 PM
thats why i asked bout trans temps..
4.10s in 3rd with a 30" tire should be 100mph no converter slip.
Sounds like the transmission is goin out or something is up..
2nd gear at 4500 should be roughly 60mph
Old May 2, 2012 | 01:31 PM
BOSS302's Avatar
This. Something is way off. I had 4.30s w/ 30" tires and my RPMs werent anywhere near this bad.
Old May 2, 2012 | 01:45 PM
now if it was 2nd gear at 4500 that would make more sense, but it should still pull a 3k# load pretty easy with 4.10s!
Old May 2, 2012 | 01:47 PM
Mangled03gmc's Avatar
Baltimore Whore
Agreed, something is out here. A 5.3 would out tow a 4.8 any day given that set up.
Old May 2, 2012 | 03:02 PM
Toward the top of the hill the tranny temp hit 190-200 so not bad there. the engine temp hit 250-260. The transmission has 135,000 miles on it. The guy who built the motor did a mild tune and said he would do a better tune once i had 3000 miles on it. The MAF was dirty and kicked off a P0171 code the other day. Would that account for the lack of power?
Old May 2, 2012 | 03:03 PM
250-260*?
you got a problem there or that was one crazy steep hill!!
Old May 2, 2012 | 03:04 PM
also i have the LTZ wheels from a tahoe
