Problem with Diagnostics port
Old Jul 19, 2002 | 11:26 PM
XLR8NSS's Avatar
Adkoonerstrator
Default Problem with Diagnostics port
Well, I tried to hookup my Atap to the truck today. For some reason Atap will not connect with the truck computer. I've tried the port setup deal and still nothing. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> I know my Atap module is still good because I can hook it up to my car with no problems.
I was planning on checking the continuity of the Diagnostic port wires to see if there is a problem. I'm assuming the five wires that run from the port go to the computer under the fuse box? If so does anyone know the pin numbers of the wires? I can trace them out but, if anyone knows it would be much easier. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Thanks
John
Old Jul 22, 2002 | 07:09 PM
red53gmc's Avatar
Default Re: Problem with Diagnostics port
Did you get it fixed?
Check the cig lighter fuse. I blew mine and couldn't hook up with ls1edit. Blown fuse was the problem. Don't remember where the fuse was b/c my friend found the problem and swapped the fuse while I was sitting in the truck.
Old Jul 22, 2002 | 07:39 PM
XLR8NSS's Avatar
Adkoonerstrator
Yeah, about 5 minutes ago. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I went out and checked the cigarette lighter fuse and BAM, it was blown. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I replaced it and Atap hooked up like a champ. Then I get to see code P0157(Transmission code) staring me in the face. <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Thanks for the tip.
Its been like 100+ degrees around here the last couple of days and unless I can fix something from inside the truck with the A/C on, it ain't getting fixed. <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
John
BigKID
Jul 11, 2024 05:28 PM
Aaron Arceneaux
Dec 21, 2015 02:54 PM
Mr. Chainsaw
Oct 18, 2015 08:00 PM
Pimpinpete
Sep 8, 2015 07:39 PM
mayko
Sep 7, 2015 12:24 PM
