Problem with Diagnostics port
Adkoonerstrator
Well, I tried to hookup my Atap to the truck today. For some reason Atap will not connect with the truck computer. I've tried the port setup deal and still nothing. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> I know my Atap module is still good because I can hook it up to my car with no problems.
I was planning on checking the continuity of the Diagnostic port wires to see if there is a problem. I'm assuming the five wires that run from the port go to the computer under the fuse box? If so does anyone know the pin numbers of the wires? I can trace them out but, if anyone knows it would be much easier. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Thanks
John
Thanks
John
Did you get it fixed?
Check the cig lighter fuse. I blew mine and couldn't hook up with ls1edit. Blown fuse was the problem. Don't remember where the fuse was b/c my friend found the problem and swapped the fuse while I was sitting in the truck.
Adkoonerstrator
Yeah, about 5 minutes ago. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I went out and checked the cigarette lighter fuse and BAM, it was blown. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I replaced it and Atap hooked up like a champ. Then I get to see code P0157(Transmission code) staring me in the face. <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Thanks for the tip.
Its been like 100+ degrees around here the last couple of days and unless I can fix something from inside the truck with the A/C on, it ain't getting fixed. <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
John
Thanks for the tip.
John
BigKID
Jul 11, 2024 05:28 PM
