possible HUGE problem..need some help/advise
for the past year. i thought my truck was a 5.3..i just took the heads off to do my heads and cam swap, and low and behold..FLAT TOP PISTONS!! so its a 4.8!! FML!! so my question is, is the cam in my sig ok to run?? i got 243 heads milled only .20..so i actually have a little more room for valve clearance then if i was to use the stockers..i just dont want the vales to be slapping the pistons. i hope the cams not too big..
well thats good to know. thanks. i had these heads based off a 5.3 when i had the work done to them. so i wasnt sure if they would work on the 4.8 or not. i know that my machinest didnt want to milled them to .30 because he said with the cam im using, the valves and pistons were extremely close to contacting. so now that i found out i have a 4.8, i was kinda leary
haha. i dying to see what these heads will do..ive got about 1100 in machine work and another 550 i paid just for the heads. they flow sheet looks better then any on the market head you can get. ill have to post a pic in my build thread of the flow/build sheet
lucas287
31
Jan 12, 2021 06:18 AM
thompson
Sep 30, 2015 09:48 AM
