ongoing rant
Old May 15, 2009 | 10:55 PM
slow.8's Avatar
Default ongoing rant
more complaining, though this was my fault. my truck has a 3/5 drop(supposed 3/5,there are only shackles out back) and im running 275/60/17`s, every once in a while ill hit a bump or dip a little too hard, and the front right tire grabs some fender. strips a sliver of rubber from the tire. im usually careful about how i drive because of this.tonight i hit a set of tracks i usually avoid, or roll slowly over, a little too fast. i wasnt even thinking about them, my mind was elsewhere. the truck bucked hard and the right front grabbed the fender 2 or 3 times. made me feel sick inside
Old May 15, 2009 | 11:01 PM
viciousknid's Avatar
Where's the Beef?
Fix it
Old May 15, 2009 | 11:27 PM
slow.8's Avatar
im going to try.id like to get some 2 inch springs. or 2 inch drop spindles and stock springs, but ive read spindles give a wider turning radius. its not exactly tight, now.
i can see where its rubbing, but i dont know how much good i could do by tapping it in a bit.
Old May 15, 2009 | 11:29 PM
slow.8's Avatar
and thanks for the sound advice.
Old May 15, 2009 | 11:33 PM
slow.8's Avatar
or, a set of stock 17`s. these centerlines make the tires stick out.
Old May 15, 2009 | 11:39 PM
budhayes3's Avatar
PT's Slowest Truck
The correct back spacing is a good idea, or you could get a shorter tire. Is the fender damaged?
Old May 16, 2009 | 12:18 AM
slow.8's Avatar
no damage.i can see where it hits the tire. it`s a small area on the inside of the fender. im going to take the wheel off and see if beating on it with a hammer helps. i just bought these tires.. the 275/55`s were too expensive... and the 275/50`s, i couldnt make my mind up on.already had a set, thought they were too short.
Old May 16, 2009 | 01:20 AM
Where's the Beef?
lol I was JFWY
I'd look at new backspacing or different tire size for the fronts.
Old May 16, 2009 | 07:53 PM
terravast4's Avatar
if you go to a 265 up fromt it helps a lot
v8
Dec 8, 2006 08:13 PM
Keith
47
May 11, 2006 01:49 AM
goshawk23
Mar 15, 2006 11:44 AM
creederado
29
Nov 26, 2005 05:21 PM
GREGGO
16
Apr 11, 2002 02:52 PM
