Oil Pressure ?
Old Feb 15, 2011 | 09:58 PM
12 Second Club
Default Oil Pressure ?
Stock 2004 5.3L
What kind of oil pressures should I be seeing?? Gettin about 25 at warm idle, up to 45ish under more than average throttle, and at cruising speed about 35.
Just wondering if this is in spec. Worried because I'm getting "Check Oil Level" warning about 2000 miles after oil change, for the second time...I assume she's burning it off in her old age 160K Plus miles
TIA
Old Feb 16, 2011 | 05:36 PM
Turbo Silverado's Avatar
Thats pretty damn low
Old Feb 16, 2011 | 07:42 PM
12 Second Club
my thoughts exactly.....bump...
Old Feb 17, 2011 | 11:57 AM
Actually thats not that bad. I wasnt paying too much attention when i posted that. Are you using synthetic oil?
Old Feb 17, 2011 | 08:28 PM
12 Second Club
No, Valvoline 10w-40.
Old Feb 18, 2011 | 08:52 AM
budhayes3's Avatar
PT's Slowest Truck
Most guys report seeing between 35-45psi on the factory gauge at warm idle and over 60 at WOT...my gauge pegs at 80 when it's colder at WOT, and I see over 40psi warm idle. Your numbers are within spec, but lower than what seems to be the norm for these trucks.
Old Feb 19, 2011 | 10:25 AM
12 Second Club
Could be due to low oil I assume...Going to top it off today and check pressure again. Thanks!
Old Feb 19, 2011 | 07:06 PM
tsduke03's Avatar
My 2005 has a GM reman new L33 motore. 25psi at warm idle and 40ish or a little above between 70-75mph. 40ish or a tad under 55-65. Cold Iowa mornings I hit 60 just taking it easy so I'm sure I'd peg if I got on a cold engine.
Been this way since motor was replacedby GM just under 6000 miles ago and the psi is pretty much same as original motor.
Texas5.3_1251
Mar 5, 2016 08:10 PM
69z-28
Sep 21, 2015 07:31 AM
Go5.3tt06
Sep 14, 2015 02:11 PM
Brandonlflr12
Sep 8, 2015 09:01 PM
Boyes50
Sep 8, 2015 12:06 PM
