No power to power seats, what is needed??
Old Jan 19, 2012 | 04:54 PM
Mangled03gmc's Avatar
Baltimore Whore
Default No power to power seats, what is needed??
What do I need to do to add a set of power seats into a truck that doesn't have them? Is the plug revisions there or is it a bit of work.. Truck is a 99-02 silvy.. Thanks
Old Jan 19, 2012 | 05:46 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Are the seats heated? And do you have a fax # that I can send you a schematic?
Old Jan 19, 2012 | 06:03 PM
Baltimore Whore
Roger
No they are not, no no number yet. i am going to go look at them tom or sat
Old Jan 19, 2012 | 06:18 PM
Really simple then. Just a 25a circuit breaker, power and ground to the switch.
Old Jan 19, 2012 | 08:25 PM
f4tal's Avatar
That's exactly how I had mine in my old 02 truck. My amp was mounted on the back wall behind my driver seat so I tapped into the 12v constant and ground and put a 30amp fuse inline. Same concept for the passenger side because I had my 4channel amp on that side. Drove it like that for 4yrs with no problems. Still working when i got rid of the truck.
Old Jan 26, 2012 | 04:35 PM
Dixon79lt's Avatar
what about the other wires on the connector? i have an 05 set of power seats and there are 2 yellow and one light green wires that are also with the orange power and black ground. they seem to go to some switch or monitor under the seat... im assuming they dont need any attention, that they are just BCM bullshit wires?
Old Jan 26, 2012 | 04:53 PM
From what I can tell, you just need power and ground for the seat adjusters & lumbar to work. But if you want the heated seats to work, you'll need the memory seat module that goes under the driver's seat, and both door modules. I have no idea if there's a way around that.
If you want schematics, let me know.
Old Jul 29, 2012 | 10:32 AM
Pollo432's Avatar
Bringing this back up. AK where are the door modules located?? In the door or kick panels?? I have all the factory wiring and module under the seat. All I need is the modules for the heated and memory I believe.
ou812sm
14
Jul 27, 2015 04:38 AM
ou812sm
Jul 23, 2015 02:11 PM
Ketis
Jul 23, 2015 12:37 PM
Aboss
Jul 9, 2015 10:28 AM
Sbrown06
Jul 9, 2015 09:21 AM
