No More LQ9's
Originally Posted by Tootall
uhhaaaa . . . . you can order your own pistons else where.
lq9 engine and lq4 have an lq4 block. Think piston and heads?? are difference between the two.
Originally Posted by 2004SSS
i thought they both had 317 heads , only differnece is the rods and pistons.
Originally Posted by Red04Silverado
Can you still buy the LQ9 block from SDPC???? I just wanted the block to start my build
not imo , the 112 cant produce enough boost on a 6.0 to where the compression ratio will hurt performance. if you have goals to go bigger than yes an lq4 would be a better choice.
Originally Posted by FBEPVP
Ive got an LQ9 that ineed to get rid of. Its an '04 of an escalade that had 4xxx miles on. PM me if your interested.
Oh well, the LQ4 is prob halfway here now, so I'll go ahead and use it.
Originally Posted by 2002C5COUPE
the blocks are the same as the LQ4's
