NNBS intake swap on a return style fuel system pics and opinions
Old Nov 22, 2017 | 10:25 PM
Shtbox's Avatar
Default NNBS intake swap on a return style fuel system pics and opinions
Hey guys doing a nnbs intake swap this weekend and read the write ups on here and a couple other threads but no pics.Im planning on putting the filter on the end of the fuel rail I haven't test fitted yet but looks like it might be a tight fit with the firewall.Heres a pic of what I got so far anybody run this set up with success
Old Nov 23, 2017 | 07:43 AM
10 Second Club
That's what I did and used a C5 corvette fuel tank transfer hose to connect it all.
Old Nov 23, 2017 | 07:49 AM
10 Second Club
Found a picture in my build thread.
Attached Thumbnails NNBS intake swap on a return style fuel system pics and opinions-80-img_20160324_113138194_hdr_8fe9b80a50c078e5d66dda9a9567e7f5e8aa4fe4.jpg
Old Nov 23, 2017 | 09:13 AM
Shtbox's Avatar
fuel tank transfer hose ok cool thanks man
Old Dec 5, 2017 | 04:54 PM
Shtbox's Avatar
just picked up this off a 6th gen as camaro at work see if I can flip the rails and make it work with the criss over fuel line
Old Dec 17, 2017 | 09:44 PM
LSrBEST's Avatar
I just used nylon fuel line with the proper quick connect ends and re plumbed it as needed (not modding any stock lines) instead of cutting the mounting tab. However I like how you cut that. I may re do mine then weld a filler on or screw/bolt a piece to reinforce the cut tab. I won't lie as of now my regulator/filter is fastened to the fuel rail with speed ties
Old Dec 18, 2017 | 02:04 PM
2002_Z28_Six_Speed's Avatar
What does return style buy you that returnless doesn't?
Old Dec 20, 2017 | 12:11 PM
turboal1's Avatar
Default Filter
here's another way
Attached Thumbnails NNBS intake swap on a return style fuel system pics and opinions-tbss-int-vette-filter.jpg
Old Dec 21, 2017 | 12:49 PM
Choda's Avatar
for you guys that are doing this, are you running a -6 back to the tank and adding your own return fitting to the tank or top of the bucket?
Would this work with a NNBS with FPCM?
Old Dec 21, 2017 | 02:13 PM
Three6GMC's Avatar
Heres my take on swapping a nnbs intake into a older return style truck. Granted not the cheapest route to take so most won't do it like this...
Used a set of the Holley rails, Magnafuel boost referenced regulator and -6 lines. This truck will be turbo but won't see but maybe 750 so -6 works fine for my setup. can always go bigger being the rails are -8. I ran my fuel lines to where they just plug right into the factory feed and return lines. Today the correct length spacers should come in and the last few pieces to the intake tomorrow so will hopefully have it installed soon.
