Need help removing Water pump
Old Jan 27, 2007 | 05:16 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by gao8302
Use a strap wrench over the pulley to hold back. Very easy.
I did something similar, except I used a chain wrench with a long handle that I wedged on the ground or frame or something (can't remember, it was a while ago). I used an old piece of belt wrapped around the pulley to avoid the chain digging into it, you can see the belt in this pic:
Old Jan 27, 2007 | 05:24 PM
Bowtie70SS's Avatar
An air chisel with a blunt bit and hammer on the edge of the nut. A second or 2 and it comes loose. BTW it is not LH threads.
Dave
Old Jan 27, 2007 | 06:14 PM
HandsomeBWouderful's Avatar
That did it! That and a second set of hands got it right off. All fixed now. Does anyone know the book rate for changing a water pump? Should we compile a list of general maintence threads and make it into a sticky?
Thanks to everyone for their input.
Old Jan 27, 2007 | 06:56 PM
gao8302's Avatar
Old Feb 1, 2007 | 09:14 AM
567234ta's Avatar
i took a piece of steel about 3 feet long and 2 inchs wide and drilled 2 holes in it and bolted it on using the bolts that hold the bell on.
Old Feb 1, 2007 | 02:39 PM
stone150's Avatar
i used a monkey wrench, when i hit it semi hard it slipped , when i whacked it hard a few times with a soft faced hammer it sliped a little then just came right off
Old Feb 1, 2007 | 02:41 PM
stone150's Avatar
it took me 2 -3hours to change my waper pump seals, but i didn't know what i was doing and could figure out what hoses to pull off, if i had to do it again it would only take 1 hour
Old Feb 1, 2007 | 03:31 PM
phasemaster1's Avatar
I used double sided tape on the pulley and a strap wrench and the cresent.
GXPJAY
Feb 13, 2022 08:15 AM
ullose272
Aug 5, 2016 02:05 PM
07NBSChevy
Aug 9, 2015 12:59 AM
