Need help with my 6.0 swap in a 98 silverado
Old Feb 5, 2017 | 08:24 AM
Beast98's Avatar
Registered User
Default Need help with my 6.0 swap in a 98 silverado
Picking up my engine here soon it's a 6.0 out of a 2001 complete with harness and computer and accessories. I knows I need mounts headers would be nice if anyone can give info on that but really need help with the wiring
Old Feb 6, 2017 | 07:35 AM
Beast98's Avatar
Registered User
Anyone able to help me out kinda need info asap don't want the truck down forever
Old Feb 6, 2017 | 10:09 AM
Jeebalow's Avatar
I posted this in a different forum at one point. Take a look hopefully it helps. It takes a lot of reading and a lot of research before the swap.
Recently figured out how to copy lots of links at once. These are all somehow related to OBS --> LSX engine swap. This is what I used. It may not be applicable to you or they may not all have 100% correct info. Hopefully it will help others. I can put them in a separate thread if that would be better. Here they are:
Engine/Efans/Wiring/Mounts/Exhaust Links:
https://ls1tech.com/forums/conversion...-oil-pans.html
https://ls1tech.com/forums/generation...r-adapter.html
Tach wiring for 99+ Vortec/LS1
http://i2.photobucket.com/albums/y28...5FanWiring.jpg
http://imageshack.us/photo/my-images...ngfansbu6.gif/
http://www.ls1truck.com/forums/lsx-t...t-routing.html
http://secure.ultracart.com/catalog/.../ACC-1030.html
https://www.performancetrucks.net/for...shrods-505622/
correct pushrod length - LS1TECH
Dirty Dingo Motorsports GM LS Gen 3 LS1 Gen 4 Conversion Swap Engine Mounts and Accessory Brackets
http://www.pontiacstreetperformance....p/exhaust.html
http://www.exhaustvideos.com/faq/how...pipe-diameter/
http://www.ls1truck.com/forums/attac...6&d=1213474335
https://ls1tech.com/forums/showpost...&postcount=294
https://ls1tech.com/forums/northwest-...hine-shop.html
http://forums.corvetteforum.com/paci...s-rebuild.html
http://forums.corvetteforum.com/c5-t...install-2.html
http://www.pacificp.com/forum/viewto...t=7367&start=0
http://www.ls1truck.com/forums/lsx-t...onnection.html
http://www.ls1truck.com/forums/lsx-t...t-diagram.html
http://www.ls1truck.com/forums/lsx-t...or-wiring.html
http://www.carcraft.com/techarticles.../photo_12.html
http://www.popularhotrodding.com/eng...re/0505em_exh/
http://www.youtube.com/watch?v=wQLhI...utu.be&t=7m30s
http://www.ls1truck.com/forums/lsx-t...g-removal.html
http://www.summitracing.com/parts/edl-3864
http://www.ls1truck.com/forums/lsx-t...e-fitting.html
http://www.ls1truck.com/forums/lsx-t...-canister.html
https://www.performancetrucks.net/for...3/#post4711055
http://wpdev.injectordynamics.com/ar...ure-explained/
http://www.youtube.com/watch?v=1Ew1YSm8jd0&app=desktop
Math to figure out if your car will run on pump gas. - LS1TECH
A/C Links:
http://www.ls1truck.com/forums/lsx-t...bracket-2.html
http://www.maliburacing.com/forum/vi...p?f=34&t=79059
http://www.novak-adapt.com/catalog/a...cation_kit.htm
http://customimagecorvettes.com/stor...cessories.html
http://www.ls1truck.com/forums/lsx-t...tegration.html
http://www.ls1truck.com/forums/lsx-t...ok-up-how.html
http://67-72chevytrucks.com/vboard/s...d.php?t=510656
NNBS/TBSS Intake Swap Links:
https://www.performancetrucks.net/for...-today-500762/
https://www.performancetrucks.net/forum...d.php?t=493269
"how-to" 03-07c NBS TBSS/NNBS intake swap Chevy Truck Forum GMC Truck Forum - GmFullsize.com
Head/Cam Swap Links:
LS1Howto.com
Hope that helps!
Old Feb 6, 2017 | 10:44 AM
Beast98's Avatar
Registered User
Looks like a lot of good info I'll have to read through it later. I still need info on the wiring if you have any info on that. I know I can get a stand-alone harness for about 250 but can't I also modify the stock 6.0 harness to work? I have complete engine harness and computer
Old Feb 6, 2017 | 11:39 AM
arthursc2's Avatar
You can modify it. Some guys on eBay sell how to manuals for ~$25, and some ppl will also do it for you ~$100.
I've never done it because I am lazy AF and didnt want my crawler to suffer a failure in the harness due to my "creativity" with the conversion, so I had my tuner convert the harness. Took him 2 days, maybe 5hrs total work.
If you didnt want to do it yourself, the shop/person who you select to tune the truck can probably do it for you. Probably cheaper if they know they are getting money from you for the tune anyway.
One other thing, I am not 100% sure: But I think your ECU is immobilized. Your tuner should be able to bypass that for you no problem.
Old Feb 6, 2017 | 12:02 PM
Beast98's Avatar
Registered User
Any good recommendations on the tune/ harness I had a guy that was going to do it but lost his info
Old Feb 6, 2017 | 12:05 PM
Beast98's Avatar
Registered User
Also will my stock trans work for now and what for spacers/ flywheel do I need to make it work. I think it's the 4l60e.
Old Feb 6, 2017 | 12:50 PM
Jeebalow's Avatar
This s what I used for reworking my harness:
http://lt1swap.com/wiringharness.htm
There's a link to that site above, but it's to a different page on the site. He has a how to there for free.
Old Feb 6, 2017 | 01:48 PM
slvrram's Avatar
I'm not sure how anyone does the conversion in 5 hours and retains traction control, AC, and cluster. Let alone doing it for 100 bucks. Standalone harness maybe... conversion so everything works... no way. If there is a true drop in harness that retains these things for $250, I'd be super surprised!
Sent you a pm.
Old Feb 6, 2017 | 03:21 PM
arthursc2's Avatar
Sent you a pm.
The OP did mention standalone, and no one except you mentioned anything about TC, AC and cluster. I mentioned my crawler, which has absolutely none of the above, and the OP didnt seem all too interested in any of it except stand alone.
