miss at idle, help!
Old Feb 12, 2011 | 08:32 PM
hawk232's Avatar
11 Second Club
Default miss at idle, help!
2002 silverado, 4.8, pacesetter lt's ORY, stock intake, ported TB, Futral tune.
It started out as a miss at idle when cold outside. after searching and seeing intake gaskets as the culprit i replaced them today. while i was at it i finally got around to pulling/replacing a broken header bolt. now that it is reassembled on the first test drive, within a minute of driving it started to miss at idle real bad (was idling around 400 or so). came home, triple checked all connections, all were good. put a timing light (just to check fire) and it seems that the entire drivers side was sporadically getting fire. pulled the main coil pack plug off, put dielectric grease and put back. long story short i thought all was well and after just running the the store it ran great for about 15 minutes then started acting up again.
sorry its so long, didnt want to leave out details
Old Feb 12, 2011 | 09:21 PM
Truckshop's Avatar
check your fuel trims. could have killed o2 sensor.
Old Feb 12, 2011 | 10:16 PM
hawk232's Avatar
11 Second Club
i have no way to check the fuel trims
Old Feb 12, 2011 | 10:18 PM
Truckshop's Avatar
unhook the battery so everything will reset. disconnect both o2 sensors and see if it clears up.
Old Feb 13, 2011 | 08:55 AM
hawk232's Avatar
11 Second Club
alright, disconnected batt and 02s went for a ride and it seems to be fixed. shouldnt having the 02s disconnected caused a cel though? it didnt... drove around till at operating temp too.
Old Feb 13, 2011 | 11:26 PM
hawk232's Avatar
11 Second Club
finally broke down and bought an actron scanner... glad i did. bank 1 sensor 1 pretty much hangs out at .040-.050mv!! guess i need a new un! must have beat it up a little bit when the header was hanging the other day while i removed a broken header bolt
Old Feb 14, 2011 | 03:56 PM
Truckshop's Avatar
You would eventually get a light with them unplugged. The sensor failed at a lean voltage and the PCM kept adding fuel to that bank trying to make it go rich. So much fuel that it was soaking the plugs. If you would have been able to Check fuel trims they would have been maxed positive.
Old Feb 14, 2011 | 09:59 PM
hawk232's Avatar
11 Second Club
the trims were maxed... the sensor was failing at .080mv, so yea... a little lean lol. swapped it out with a rear working o2 and all is well now! thanks for the help!
OHsixLS3
Nov 22, 2015 07:45 PM
bearden86
26
Nov 15, 2015 03:58 PM
BlownHD
Oct 3, 2015 12:24 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
trxmxzx
Sep 29, 2015 07:42 AM
