Low idle after fuel pump replaced
Old Aug 18, 2019 | 11:07 PM
comeaux818's Avatar
5 Year Member
Default Low idle after fuel pump replaced
Came home from work friday, loaded kids up to go to the gym and truck started idling extremely low. Turn around with it basically dying in my drive way. After it would start but sputter out. Figured fuel pump because one of my coworkers years ago the same thing happened when i was in the truck with him. Finally get to replacing it this evening. Had to change to updated plug, used butt connectors that were supplied with it but tom morning im going back to solder it with heat shrink. Now it starts and runs but idles at 400/500 rpm.
Seeing if any one might have an idea as to why or ran into it. As always, when i get it figured out ill post back to try to help the next man. Thanks in advanced.
Old Aug 18, 2019 | 11:19 PM
Feed's Avatar
While your in there, replace filter. Check supply line connections.
Old Aug 19, 2019 | 12:22 PM
comeaux818's Avatar
5 Year Member
I replaced the filter last year. It only does it in drive right now idling. Had it idling in park for 30 mins and it was fine. Once it cools off a lil more im going to go back at it.
Old Aug 19, 2019 | 03:54 PM
FFDP's Avatar
Commanded idle hot in drive is only like 525.
Old Aug 19, 2019 | 10:55 PM
arthursc2's Avatar
My truck idles like 500rpm. You saying that's not normal for you? Where did she used to idle? What are they supposed to idle at?
Old Aug 22, 2019 | 08:49 AM
comeaux818's Avatar
5 Year Member
Mine idles in gear at a stop between 550 bouncing as low as 350. This weekend im going to squirt starter fluid all around to see if maybe a leak or something. The whole ordeal sucked because i couldnt find a 255 or 450 walbro pump locally and needed my truck because i do electrical work on the weekend for myself. Even tried seeing if i could find a supra pump locally and cross references to them. You have to buy the whole assembly unless you waited for it to get shipped. Good thing is now i have another bucket to modify when the time comes i guess. Ill update soon.
Old Aug 22, 2019 | 03:04 PM
MikeGyver's Avatar
Don't waste your time looking for a vacuum leak.
05cc
May 5, 2009 09:54 PM
Frito Bandito
Nov 20, 2007 07:44 PM
4.8LGMC
Aug 21, 2006 02:50 PM
derek_silvy
13
Aug 24, 2004 07:18 AM
Apr 28, 2003 06:57 PM
