Problem with idle... fuel pump?
Old Aug 6, 2006 | 09:37 PM
4.8LGMC's Avatar
Default Problem with idle... fuel pump?
The other day while i was at work (saturday) i went to adjust some things on my programmer (superchips) on my 2003 GMC (4.8L). All I did was adjust the shift pressure and shift points. The I started it up after it was done installing the mods and all of a sudden after I put it in gear and drove like 50 feet, it died. I've had my programmer on for almost a year and have never had any problems with it. So I changed my fuel filter and put some injector cleaner in the gas tank. Nothing. Still does it. It also does it while i'm driving at low rpm's (around 1000) and slow speeds (10 or slower). Could my fuel pump be going out? Any help would be greatly appreciated.
Old Aug 7, 2006 | 02:33 PM
Superchips Tuner's Avatar
LS1TECH Sponsor
Default sc reply
Is the theft light going crazy?
Is there any DTC's (diagnostic trouble codes)
If you want you can PM me and I will help with what I can.
Stay Tuned!!!
Ron
Old Aug 7, 2006 | 04:55 PM
m7 rocket's Avatar
Did you let it idle for 10 minutes or so to let it re learn the idle? Just an idea. You could try putting it back to stock program try it and see, then maybe go back to programmer tune and see. I think you can go from there...
Old Aug 7, 2006 | 05:36 PM
Derek @ EDO's Avatar
FormerVendor
Try the simple stuff first, Could be the plugs. It happned to me once, my front 02's were out for a good while and the carbon build up just killed the engine one day while i was driving; Changed the plugs and she ran like new.
I believe the fuel pump wont sputter the fuel like that, its dead and does nothing or it works; i may be wrong though.
Old Aug 21, 2006 | 02:50 PM
4.8LGMC's Avatar
it was the throttle body. i talked to my local gm dealership to one of the techs and he said to clean out the throttle body. I took a can of throttle body cleaner, opened the throttle body butterfly, cleaned it out and it worked....
slowlsx
Aug 13, 2015 08:28 PM
roprisiu
Aug 9, 2015 10:47 PM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
