Am I slow b/c of fuel pump?
Alright, please see my other post if you are not familiar with how slow my truck is.
If you're not a ls1tech surfer.... check this for explination:
https://ls1tech.com/forums/showt...t=207464&page=1
In short, I do 0-60 in 9.47 seconds -- slower than my mom's stock Tahoe.
Anyway... in addition to my slowness I've noticed some "bumps" at idle. I thought it was just a little bit of improper timing due to my stock pcm trying to leanr the cam. Well, it still does it and seems to have gotten even worse. Today when I got home, I got out to listen from the engine bay and noticed a high pitched whining from under the truck right as I stepped out. I said to my dad, "that sounds like the fuel pump." I got underneath and stuck my ear to the tank and sure enough, its coming from the gas tank. Very high pitched, annoying whine. Does this happen every now and then, or is my fuel pump just plain dieing?
Last time I listened for it (two days ago) I heard it whine as I switched the ignition on and it seemed to have that normal whine. Now its whining after I drive it! So, what is going on? Is this a sign the fuel pump is dieing? Can I blame those "bumps" at idle and my turtle-like speeds on a bad fuel pump?
What do you guys think?
My dad bought one for another vehicle one time and it was ungodly expensive. How much do they run for an oem pump? How much for an aftermarket and would that be neccasary?
Hope I helped a little.
Philip S.
Thanks for the help man!
I'm hoping that this can be at least a little to blame for my super slow 0-60 time. Can anyone explain what's mechanically/electrically happening to make it whine?
Any more thoughts?
Any more thoughts?
My pump sounds alot louder when my gas tank gets closer to empty. I think because the pump isn't submerged. Could this be what's happening?
Also, they will whine louder if your filter needs to be replaced.
Well, if the whining comes from the gas tank than yes, its the fuel pump.
I have over 1/4th of a tank right now. I could put some more in it and see how it goes, but I've never noticed this before in the 5 months I've owned the truck.... and now I'm having problems.
Denali: I have run sea foam through it and stuff like that before, so I doubt the injectors are that dirty.
