LONG Start for 5.3, AHH!!
Old Jun 5, 2004 | 05:22 PM
Default LONG Start for 5.3, AHH!!
Ok i asked this awhile back, I still takes my truck about 10-15 to start my truck when you let it sit awhile? i replaced the fuel filter and checked the vaccum line on the regulator for leaking fuel, but found none, spark plugs didn't make a difference either. Whats wrong? I cannot figure this out and i don't want to take it to the dealership! help me guys
Old Jun 5, 2004 | 06:30 PM
v8
17,16,15,14,13,12,11 Drvr
well did this start after the tune? not trying to start anything. Have you ever had the injectors cleaned?? have you cleaned the T/B blade path?? later kevin
Old Jun 6, 2004 | 12:58 PM
Okay it did the exact same thing before the westers tune, i have cleaned the TB myself real good, but never messed with the injectors.
Old Jun 6, 2004 | 02:16 PM
one03sierra's Avatar
Formerly one92rs
Talking
like v8 said get the injectors cleaned. i had mine done and it made a bigg difference. it cost 100.00 don here.
Old Jun 6, 2004 | 03:50 PM
gonzo 6.2's Avatar
can you hear the fuel pump when you first turn the key on?
Old Jun 6, 2004 | 06:20 PM
BlownChevy's Avatar
blownerator
25 Year Member
Have you tried replaceing the Fuel Pressure Regulator?
Old Jun 6, 2004 | 06:26 PM
FILE's Avatar
Where is the fuel pressure regulator?
Old Jun 6, 2004 | 06:28 PM
BlownChevy's Avatar
blownerator
25 Year Member
Driver side fuel rail, gold in color should have a vacume line going to it.
Old Jun 7, 2004 | 12:06 AM
Onyx 02's Avatar
I had similar problem with my 99 when I'd let it sit. I put an Optima red-top battery in it. I noticed that even when I let it sit for 2 weeks, it would fire up right-away when I turned the key. I don't know if this helps any!?
Old Jun 9, 2004 | 07:47 PM
I can hear the fuel pump when i turn the key to the on position. Now on the regulator, should i really replace it? I noticed that it has a filter in it, could it be clogged or something?
ferrellrooster
Mar 6, 2025 03:22 PM
ARC
57
Feb 21, 2022 10:54 AM
shawn96gmc
May 17, 2016 04:15 PM
carid
Aug 2, 2015 08:45 PM
steves86ta
Jul 28, 2015 10:21 AM
