leaking near cv shaft.. is it the seal"
Old Feb 11, 2016 | 04:11 PM
40series's Avatar
Default leaking near cv shaft.. is it the seal"
my drivers side cv shaft is on the way out its clicking bad when i turn the wheel right. The cv shaft asswmbly seems to be leaking near the mating area too
what do you guys think ?????
Old Feb 11, 2016 | 04:55 PM
FFDP's Avatar
Leaking out of the diff housing??
If so, then yeah you need a new axle seal. The drivers side is the easier one to replace.
Old Feb 11, 2016 | 04:59 PM
40series's Avatar
Default clicking when i turn
but its clicking when i turn right though
Old Feb 11, 2016 | 05:30 PM
FFDP's Avatar
Yeah??
You already said the cv axle is on it's way out, so you should be replacing it.
Old Feb 11, 2016 | 06:28 PM
40series's Avatar
Default is this good technique?
Yeah??i saw a vid of a guy fix the seal a slide hammer wont work because theres not enough room , he hit the shaft on the back side with a hammer ... the C clip remained in the diff ,, my question is
Old Feb 11, 2016 | 06:52 PM
FFDP's Avatar
I am completely confused as to what you are wanting or asking now.
The CV clicks, so that's bad and needs replacing. The seal on the diff is leaking aswell from what you are saying too?? If that is the case, replace the seal at the same time.
Remove the axle from the truck and just smack the stub shaft out of the front diff with a hammer. I've done it and seen it done many times over in the shop I worked in. Should be a quick 10 minute seal change.
Old Feb 13, 2016 | 10:36 PM
40series's Avatar
Default question about the c clip on the half shaft
im just worried about the c clip on the half shaft when knocking the shaft out///////////////???????????????????????????
Old Feb 15, 2016 | 04:47 PM
Zachary650's Avatar
The c clip should remain in the axle shaft just remove the shaft replace the seal and reinstall the axle shaft. Just did this in my truck.
Brando5641
Nov 18, 2020 05:32 PM
MARCYTECH
Feb 16, 2016 04:12 PM
hotrodjohnson21
Jan 28, 2016 06:10 PM
BCraven1018
Jan 24, 2016 12:24 PM
1bad2k
Jan 20, 2016 09:32 PM
