Know anything about 2.2 L 4cyl?
Old Apr 15, 2008 | 08:21 AM
Yenkonoma's Avatar
Default Know anything about 2.2 L 4cyl?
I've got a 97 S10 w/a 2.2L 4cyl for my daily driver with 218,000 miles..... yes it's a but it gets good mpg!
Yesterday on my way home the truck suddenly lost power and the SES lightthat is on spurraticly went out. I can't give ity anymore than about 1/4 throttle it feels like it's got a 10,000 lb trailer hooked to it. I thought ithe intake was blocked, when i pulled it off it almost sounds like it's poping back through the intake. I thought burnt or stuck valve, but the compression is about 190 psi across all 4 cylinders. Anyone know anythingh about these motors? PLEASE HELP!
I went to some of the s10 specific forums but it seems like everyone on there is like 16, so they weren't much help.... plus I have to waut 48 hrs after i register before i can post.
Old Apr 15, 2008 | 08:47 AM
ThirdCoast's Avatar
www.s-seriesforum.com is the place to go. No 16 year olds.
Old Apr 15, 2008 | 09:17 AM
shandy294's Avatar
It might have jumped timing due to a worn t-chain and/or gears. Check your valve timing.
Old Apr 15, 2008 | 11:56 AM
sickREDsierra's Avatar
damned 16 year olds.
Old Apr 15, 2008 | 12:28 PM
Yenkonoma's Avatar
thats right ...damned 16 year olds... seems if you hint to what you think the problem might be... that is what it is nothing else.
I'n kinda thinking timing chain issues myself. Also read somethingh about Cam position sensor or crank position sensor. What happens if they go bad?
Old Apr 15, 2008 | 01:12 PM
bigbadwolf54's Avatar
13 Second Truck Club
clogged catalytic converter????? I know those are easy to remove and "dislodge" the restriction....
Old Apr 15, 2008 | 02:37 PM
Yenkonoma's Avatar
That was gutted by the guy i got it from.... so I'm pretty sure thats not the issue
Old Apr 16, 2008 | 09:14 AM
Yenkonoma's Avatar
Finally got the fan off last night and pulled the timing chain cover off..... looks like the cam is about 3 teeth off rom where it should be I'm thinkin that might be a LITTLE issue.
Old Apr 16, 2008 | 10:14 AM
I;m with the Wolf here, the Converter will cause it to do the EXACT same thing. I would make sure it's been gutted. And if it's been gutted without proper programming, the your PCM can put you in reduced power mode.
What led up to having the cam jump time? What were you doing before it happened?
