I must have demons in this fawkin truck, the fuel
Old Nov 17, 2008 | 07:58 PM
Mangled03gmc's Avatar
Baltimore Whore
Default I must have demons in this fawkin truck, the fuel
Pump, runs perfectly fine out on the bench. I have ran it 5 different times, not one funky noise coming from it.. Smoother and as quiet as can be. I am about stumped on this.. I don't what the prob could be. I put my finger over the the discharge side, it build pressure like a ****... What could it be ???? I am about disgusted with it...
John
Old Nov 17, 2008 | 08:01 PM
phasemaster1's Avatar
How come the bosch site say's its a inline pump?
http://boschfuelpumps.com/
Old Nov 17, 2008 | 10:13 PM
marlboroman71818's Avatar
because it is. My thoughts on your problem is your intank pump is alot larger than your inline. Your inline cant keep up with your intank pump and is causing excess stress and pressure on your intank when running because it cannot flow as much at the same psi.
Old Nov 17, 2008 | 10:25 PM
dirt track racer 81's Avatar
this is what ive been thinking all along. its like having a plugged fuel filter, which can cause a pump to fail
Old Nov 17, 2008 | 10:35 PM
Baltimore Whore
Ok ok, I have removed the 255inline that was infront of the bigger intank. Problem is still there/here.. I pulled the pump ran it a few times, even put my finger over the discharge side, it builds pressure. I think ima try it back in the tank tom.. It makes a fierce noise in the tank, but as quiet as can be on the bench...Just can't figure why the pressure is dropping.. Could it be my FPR ??
John
Old Nov 17, 2008 | 10:38 PM
what kinda regulator you got?
Old Nov 17, 2008 | 10:40 PM
Baltimore Whore
I am running the stocker in the fuel rail, was told by many to KEEP the one in the rail..
John
Old Nov 17, 2008 | 10:46 PM
are they sending you a new pump?
Old Nov 17, 2008 | 10:54 PM
Baltimore Whore
If it turns out this one is truly bad, they will. I am going to put it in a bucket of gas tomorrow, see what it does...
John
Old Nov 17, 2008 | 10:57 PM
whats the reason for keeping the one in the rail?
