I know this has been discused, but havn't seen for stock
Old Jul 10, 2008 | 03:45 PM
Mangled03gmc's Avatar
Baltimore Whore
Default I know this has been discused, but havn't seen for stock
tranny temp gauges, just aftermarket ones. Just curious where you guys that do have the stock gauge, needle sits after driving for a bit. Mine sits about right in the middle, so that is the norm, I hope... I know that the happy med is about 180 give or take a lil
Thanks much
John
Old Jul 10, 2008 | 04:47 PM
oldred95's Avatar
Mine was showing 171 the other day with the Tech II hooked up. That would be on my 99 silverado.
Old Jul 10, 2008 | 05:00 PM
nonnieselman's Avatar
you can pretty much say double the Ambient Temp... to a certain degree.
Usually if its 70* outside, EFI live says 140ish.
if its 90* it shows 180ish
but its been awhile since ive looked at it..
My Autometer Trans temp gauge shows about 10* lower than what the PCM says..
Old Jul 10, 2008 | 06:07 PM
Baltimore Whore
Hmmm just returned from a drive, it crepped up past the middle mark and to the next big line, right before 300, I am going to say that is 250 I think I need a bigger trans cooler, but it is 90 outside so, what you all think ? Now it was sittin a bout 10 min before I snapped this so a tad of heat soak snuck up
Thanks guys
John
Old Jul 10, 2008 | 06:25 PM
dirt track racer 81's Avatar
get a bigger cooler
Old Jul 10, 2008 | 06:43 PM
Baltimore Whore
Originally Posted by dirt track racer 81
get a bigger cooler
Would we say that is 250, I am running the cooler that came with the trans, I am going to go with a 20-25klb cooler...
Thanks
John
Old Jul 10, 2008 | 06:47 PM
40,000gvw here..its like an intercooler,,yes id say 250..maybe 249.6..any how it says 100 and 300 and the middle mark would be 200 so between 200 and 300 is 250..thats the way i see it
Old Jul 10, 2008 | 07:10 PM
ap2002's Avatar
250 is high for the tranny temp!! you'll burn the tranny if you keep on running it that hig.. dont mess around and get the 40kgvw from tru-cool, like dirtrackracer said, it looks like an intercooler cause its big, but it keeps the temps way low!! my truck in this 90+ degree weather and ******* it everyonce in a while would see 160-170degrees MAX, if i would just cruise it would be between 130-145, best tranny cooler in the market that really does the job like its suppose too...
Old Jul 10, 2008 | 07:21 PM
dewmanshu's Avatar
Moderately Differentiated
WHAT?!?!? Unless you have a tiny *** cooler the size of my hand OR you were towing stuff with a high stalled converter and a small cooler I say something else is wrong. I won't knock the fact that large coolers are kick ***, but unless you have a high *** stalled converter you should NOT be seeing temps that high IMO. ap is right, you will smoke your ****.
Does it cool down at all if you hit the highway and the converter locks for a few miles?
Old Jul 10, 2008 | 07:23 PM
Baltimore Whore
So they are one of the top coolers, I was just looking at the jegs Hp coolers, a few derale coolers.. I don't want any junk..
Again thanks
John
