HVAC Controls Malfunction - Stays on full heat
Old Feb 3, 2006 | 09:59 PM
Rado01's Avatar
Default HVAC Controls Malfunction - Stays on full heat
I've had and intermittent problem with the HVAC controls that is now happening almost daily. . . If I start out with the truck on heat (cold mornings), then switch to cold vent, the HVAC continue to blow hot air. . . with the temp **** on full cold, and the flow control on vent or any other positions.
Usually if I turn the engine off, and restart, it is OK again. Has anyone else had to deal with this one? What is the fix?
Old Feb 3, 2006 | 11:25 PM
BlownChevy's Avatar
blownerator
25 Year Member
What year truck?
Old Feb 4, 2006 | 07:57 AM
doublenot's Avatar
my truck is doing the same ****. It really pisses me off. Anyone have any idea. Mine is a 2005.
Old Feb 4, 2006 | 09:27 AM
BLACKND's Avatar
Had that **** happen to my 04 GMC Sierra when I had it. It sucks and trust me, it will be a recurrring nightmare. The dealership changed out what they call an a/c recirculating switch or relay. I think thats what it was, I will have to check my serivce documents. Mine went out and they replaced it and then about every month it would go out again.
Old Feb 4, 2006 | 06:28 PM
Rado01's Avatar
Originally Posted by BlownChevy
What year truck?
Sorry about that ... It's a 2001
Old Feb 4, 2006 | 06:37 PM
BLACKND's Avatar
Oh, went back and checked my records. They called it an a/c cycling switch.
Old Feb 4, 2006 | 10:28 PM
Rado01's Avatar
Thanks for looking that up !
Anyone else? On my 01 Silverado, It will blow highly heated air when just on vent, so I'm not sure its related to the a/c cycling switch. I'll have to look that one up in my manuals.
Old Feb 5, 2006 | 01:13 AM
AintNoHo's Avatar
Happened on my truck when I pulled and replaced the engine. I found a ground strap on the back of the engine block which I forgot to replace. I suggest you make sure the block, body, frame, and battery are all strapped together for a good ground.
Old Feb 5, 2006 | 07:50 AM
virgils4.85spd's Avatar
Default I have an 01
Mine does the same thing, and its an 01 silv. It pisses me off!!!!!!
Derek
Old Feb 7, 2006 | 08:57 PM
Rado01's Avatar
Derek
I know someone of this forum knows the fix, Anyone ???
Blue03sss
Mar 7, 2019 05:06 PM
thunder550
Oct 8, 2015 04:53 PM
JCW
Sep 22, 2015 03:59 PM
chvy=power
Sep 8, 2015 11:05 AM
bsgiffor
Jul 19, 2015 11:14 AM
