high pitch noise
Old May 5, 2007 | 11:38 PM
tahoe SS02's Avatar
Default high pitch noise
So i have a noise coming from my left front tire.
The guy who usually does the work on my car said he can't hear it.... he's old and can't hear some pitches.
Any ways. while i'm driving straight it will make a high pitch sound that's very inconsistant.... when i press the brakes it goes away. Also the sound doesn't happen right away, it seems like it has to worm-up first then it starts to squeak.
So i just got done replacing my rotors and pads... still squeaks!!
What do you think it is?????
Old May 6, 2007 | 08:32 AM
budhayes3's Avatar
PT's Slowest Truck
Possibly the metal dust shield rubbing on the rotor?
Old May 6, 2007 | 10:02 AM
ReSpAwN DeMoN's Avatar
that sounds exactly what it is..
simply get under there and bend the shield back just a little bit.. see if it goes away?
Old May 6, 2007 | 06:41 PM
tahoe SS02's Avatar
Default noise
No it's not that, i checked....
The sound isn't a grinding noise, it a very high squeak. It happens once the car gets warm and is very speradic (sp?).
squeak.........squeak..squeak...............squeak .squeak.squeak.........................squeak..... .squeak........ and as soon as i hit the brakes it goes away.
Old May 6, 2007 | 06:42 PM
Derek @ EDO's Avatar
FormerVendor
wheel bearing?
Old May 6, 2007 | 10:16 PM
budhayes3's Avatar
PT's Slowest Truck
Sounds like the brake pad wear sensors are hitting the rotors, but you mentioned that you just replaced the pads and rotors. Maybe one of the sensors is bent and touching the rotor? Or, something in the wheel bearing/hub assembly or abs reluctor/sensor? Is there something on the wheel that's hitting the caliper, like a mis-placed stick on wheel weight?
Old May 6, 2007 | 10:37 PM
weird..
but I'm sticking with the dust shield.. on my other car it looked like it wasn't bent but it was bent just ever so slightly that you heard it.. at low speeds it was a high pitched squeek very slow then as I sped up it squeeked faster and you heard it loud when passing other cars.
it almost sounded like an alien under the car
Old May 7, 2007 | 07:43 PM
TarheelZ's Avatar
Originally Posted by ReSpAwN DeMoN
...it almost sounded like an alien under the car
Okay, now I'm thinking: does he REALLY know what an alien under the car sounds like? JFWY!
Old May 7, 2007 | 07:45 PM
FormerVendor
lmfao,,,, Alien!
lukn4trbl355
Oct 21, 2015 11:19 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
Velocity1
Oct 2, 2015 08:01 AM
carid
Oct 1, 2015 09:22 AM
tim wellington
Sep 29, 2015 10:17 PM
