Hey ULASZEK - good article in GMHTP
Old Aug 25, 2005 | 07:53 PM
BigTex's Avatar
Default Hey ULASZEK - good article in GMHTP
Good work on this months article. After leaving us hanging on the previous one, I didn't know what to expect.
Any chance we could get some more detailed info on your air temp numbers? I'd like to see more info on the pre and post intercooler temps along side the temps reported by the relocated IAT sensor.
Thanks
Richard
Old Aug 25, 2005 | 08:20 PM
goshawk23's Avatar
Truck addict
i need to get that subscription. i have been getting it off the shelf when i can find it. seems to be some good info always available in that one.
Old Aug 25, 2005 | 09:06 PM
BigTex's Avatar
GM High Tech Performance is a must read magazine for us owners of GEN III trucks. Most of the stuff deals with Fbodys, but most parts interchange, so its relevant.
In this months issue, Mr. Ulaszek finished up his Radix install on his 5.3 truck. Article had dyno numbers and some good info on air temps. He installed sensors before and after the radix intercooler, so we can see how well it cools.
Old Aug 26, 2005 | 08:14 PM
JohnUlaszek's Avatar
Thanks Tex,
That post sure grabbed my eye
Glad you liked the article. I will be doing a tuning article in an upcoming issue and I will be using the thermocouples to test a couple of ideas.
Are you looking for temps under specific conditions?
Thanks again
John
Old Aug 26, 2005 | 08:30 PM
goshawk23's Avatar
Truck addict
just knowing that the trucks are getting more coverage makes the subscription worth it. btw, my last issue came from the newstands in germany. granted on base but still, it was germany...
Old Aug 27, 2005 | 12:18 AM
BigTex's Avatar
Hey John, thanks for replying, I hoped you would. I am extremely interested the reading your getting from the thermocouples compared to the readings the PCM is getting from the relocated IAT sensor. I found your comparison between the temps pretty interesting. I've noticed my PCMs IAT readings respond a little sluggishly and think its partly due to the location and partly to heat soak. Its not uncommon for me to see IATs keep rising after a run before they start to fall.
If you don't mind, I'd just like to see some raw numbers of your readings under different conditions. It would help to see whats really happening compared to whats the PCM is being told. I've seen my IAT readings climb to 170+, which probably means they are actually higher.
Old Aug 30, 2005 | 09:04 PM
Goshawk,
I was was a Jet Engine mechanic in the Air Force, so I am really grateful I can keep you guys entertained even the slightest bit. Glad to hear you guys are getting GMHTP in Germany, sometimes its hard to pickup on the newstands stateside, but we are working on that.
BigTex,
I dumped as much as I could into the latest article as far as data goes, and I plan to continue to discuss this is future articles, but as I get more data I will keep you guys updated.
Old Aug 30, 2005 | 11:18 PM
duwem's Avatar
There suspension install sold me on the Hotchkis sway bars, as my sig says, there on the truck and performing beautifully, I cna pitch it sideways comming out of a corner, and this is with the peg leg stock not limited slip diff.
Old Aug 31, 2005 | 01:08 AM
PappyDan's Avatar
Tribe Shaman
Tex could you post what the article had in it, i do not have any issues of this mag but i would like to read about the before and after temps on the intercooler.
Raylar Engineering
Aug 26, 2015 10:36 PM
mrhino
Aug 7, 2015 10:01 AM
Cm_gmt800
Aug 3, 2015 09:13 PM
Mark Johnson
Jul 28, 2015 08:56 AM
ALynch
Jul 6, 2015 09:49 AM
